Diffused Red and Green Indicator LED 18mm Round
PRODUCT ID: 4042
DESCRIPTION
This LED Is super chonky! Bigger than your average LED, it has a big, bold, and
beautiful diffused body that measures approximately 18mm diameter. Inside is
nestled a bi-color red and green LED, just like you're familiar with. Each with
about 2.3V forward voltage. Add a resistor in series and connect to a battery or
microcontroller pin for a gorgeous glow. The center pin is the common cathode,
so connect that to ground, then use the two outer pins to control the red and
green elements inside.
Could be a great addition to a control panel, cosplay, or art project. They go
easily into a breadboard and will add that extra cool zing to your project.
If you need some help using LEDs, please read our "Introduction to using LEDs"
tutorial for any electronics project.
TECHNICAL DETAILS
DC Forward Rated Current: 25mA per LED
DC Forward Voltage: 2.1V for red, 2.4V for green (approximate)
Operating / Storage Temperature: -40°C To +85°C
Dimensions (DxH) (excluding pins): 17.8 diameter x 10.8mm
https://www.adafruit.com/product/4042/2‐8‐19
很抱歉,暂时无法提供与“4042”相匹配的价格&库存,您可以联系我们找货
