4081
4081
    ADAFRUIT
    DIP2模块
    振动 传感器 通孔
4081 数据手册
      Flat Vibration Switch - Breadboard friendly PRODUCT ID: 4081 This is a low sensitivity, directional vibration-induced trigger switch. Inside is a very soft spring coiled around a long metal pin. When the switch is bumped from the side only, the spring attached to the first pin touches the center pole to make contact with the second pin. So when there's a bump, the two pins will act like a closed switch. When everything is still, the switch is open. Great for educational projects and wearables! Compared to most vibration switches, this one is flat, and will solder nicely into a PCB without sticking up, and is also breadboard friendly. TECHNICAL DETAILS Product Dimensions: 18.0mm x 15.8mm x 5.5mm / 0.7" x 0.6" x 0.2" Product Weight: 0.5g / 0.0oz  Diagram                                                 https://www.adafruit.com/product/4081/2‐8‐19
很抱歉,暂时无法提供与“4081”相匹配的价格&库存,您可以联系我们找货
    • 1+17.71200
    • 200+7.07400
    • 500+6.83640
    • 1000+6.71760
