4099
4099
    ADAFRUIT
    探头组件
    湿度温度传感器 I²C ±2% RH 用户自定义
4099 数据手册
        SHT-30 Mesh-protected Weather-proof Temperature/Humidity Sensor - 1M Cable PRODUCT ID: 4099 Take your next outdoor sensor project to the next level with this SHT-30 based temperature/humidity sensor. The sensor includes a dual-use sensor module from Sensirion in a sintered metal mesh encasing. The casing is weatherproof and will keep water from seeping into the body of the sensor and damaging it, but allows air to pass through so that it can measure the humidity outside. While it is designed to be submersible in water, it's always best to avoid long-term submersion (over 1 hour at a time), and it obviously would only give you temperature readings. For that, our metal-cased temperature sensors would be better! This sensor is best for simply placing outside for exterior weather sensing. The SHT30-D sensor has an excellent ±2% relative humidity and ±0.5°C accuracy for most uses. Unlike earlier SHT sensors, this sensor has a true I2C interface. The sensor is essentially just a Sensiron SHT-30 digital sensor (much like our breakout here) with the 4 data/power wires brought out so any SHT-3x code for a microcontroller will work. Check out the tutorial for Arduino and CircuitPython/Python, and more! The 1 meter long cable has four wires: Brown = VCC (3-5VDC), Black = Ground, Yellow = Clock, Blue = Data. TECHNICAL DETAILS  Sensor body dimensions: 14mm diameter, 50mm long  Cable length: approx 1 meter  Contains an SHT-30 Temperature/Humidity sensor  Four wires: Brown = VCC (3-5VDC), Black = Ground, Yellow = Clock, Blue = Data       https://www.adafruit.com/product/4189/6‐6‐19
很抱歉,暂时无法提供与“4099”相匹配的价格&库存,您可以联系我们找货
    库存:199
