4163
4163
    ADAFRUIT
    光导管 单路 透明 弹性 3.3'(1.0m)
4163 数据手册
Side-light Fiber Optic Tube - 4mm Diameter - 1 meter long PRODUCT ID: 4163 Yay, a plastic tube! No, we jest. This is no ordinary plastic tube, but rather a side-lighting fiber optic tube. This is a pretty neat way to glow up. Light in the fiber optic cable zooms through the core by constantly bouncing off of the edge of the molded plastic, a principle called "total internal reflection" (which also kinda sounds like a very expensive meditation island retreat). When the light pipe doesn't have total reflection, you can get a nifty lighting effect from the light illuminating the plastic tubing. This tube is 4mm diameter, but is nice and flexible plastic and when lit with a powerful LED, has a nice glowing effect. You can cut it down from 1 meter with diagonal cutters. Note: This is just the tube, and does not include an emitter LED. You'll also want to grab one of our fiber lights. We've got them in red, green, blue, white, and Adafruit pink! TECHNICAL DETAILS  Diameter: 4mm  Length: 1 meter                                                   https://www.adafruit.com/product/4163/4‐26‐19
4163
PDF文档中包含以下内容:
物料型号:STM32F103C8T6 器件简介:32位ARM Cortex-M3内核,主频72MHz,64KB Flash,20KB SRAM,37GPIOs,2个12位ADC,3个通用定时器,2个高级控制定时器,3个通信接口,支持多种工作电压。
引脚分配:共48个引脚,包括电源引脚、地引脚、I/O引脚、晶振引脚等 参数特性:工作电压2.0V至3.6V,工作温度-40至+85摄氏度,封装LQFP48 功能详解:详细介绍了各个外设模块如GPIO、ADC、定时器、通信接口的工作原理和使用方法 应用信息:适用于工业控制、消费电子、医疗设备等领域 封装信息:LQFP48封装,尺寸7x7mm,引脚间距0.5mm
很抱歉,暂时无法提供与“4163”相匹配的价格&库存,您可以联系我们找货
