4170
4170
    ADAFRUIT
    GPIO RIBBON CABLE 2X8 IDC CABLE
4170 数据手册
        GPIO Ribbon Cable 2x8 IDC Cable - 16 pins 12" long PRODUCT ID: 4170 Connect this to that! If you want to bridge those contacts out onto another PCB, you'll want this GPIO Ribbon Cable! Comes in a classic Adafruit Black, has a nice soft flexible 16-line 0.05" ribbon cable and keyed IDC connectors on both ends. It's perfect for use with our GPIO Expander bonnet or with any of our RGB LED Matrices if you want to chain them together or extend the cable a little farther. This cable is 12" long and has 16 pins (2x8) in 0.1" x 0.1" spacing and two sockets crimped on either end. Pin #1 is marked with a white stripe down the side. TECHNICAL DETAILS                                                        https://www.adafruit.com/product/4170/5‐7‐19
4170
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种通用型晶体管输出光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,其中1脚为发光二极管的阳极,2脚为阴极,3脚为集电极,4脚为发射极,5脚为集电极,6脚为发射极。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms,输入电流为10mA,输出电流为50mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:广泛应用于通信设备、工业控制、医疗设备等领域。
7. 封装信息:采用DIP-6封装形式。
很抱歉,暂时无法提供与“4170”相匹配的价格&库存,您可以联系我们找货
