2 x AAA Battery Holder with On/Off
Switch & JST PH Connector
PRODUCT ID: 4191
This battery holder connects 2 AAA batteries together in series for powering all
kinds of projects. We spec'd these out because the box is nicely slim, and 2
AAA's add up to about 3V for low-voltage electronics projects, plus it has a
nifty on-off switch.
Fits any standard AAA battery. When using rechargeable NiMH the output
voltage will range from about 2.7V with charged batteries to 1.8V at the end of
life with a nominal voltage of 2.4V. When using alkalines, the output will range
from 3.2V with new batteries to 2.2V at the end of life with a nominal voltage of
about 3V.
The polarity matches that of our 2-pin JST cable and Li-Ion/Poly batteries. Uses
a genuine JST connector so it won't 'catch and tear' in JST connectors.
This is a great update to the battery packs that come with micro:bit's because it
has an on-off switch built in so you don't have to yank it out to turn off the
power.
TECHNICAL DETAILS
Cable Length: 6" long, terminated with a genuine JST-PH 2 pin connector
Holder Dimensions: 62.5 x 25.3 x 15.4mm
https://www.adafruit.com/product/4191/5‐3‐19
很抱歉,暂时无法提供与“4191”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+17.204001+2.23647
