Multifunctional USB Digital Tester - USB A
and C
PRODUCT ID: 4232
While this may appear to be an electronic shuriken, it's actually a Multifunctional
USB Digital Tester!
This handy (pun intended?) tool can measure voltage, current, power, charge
time, and other measurements for USB A, Micro B, and USB C! It features a
colorful display that pops up when you plug in a power supply. Each click of the
button gives you a different display and readout. A long press will reset the data
for when it does Coulomb-counting (total power consumption). We like the
simple display that comes up first with big Voltage and Current output, but you
have lots of options.
There's 4 connectors so you can go from type A to C, type A to A or type C to C.
Works great with laptops, smartphones, tablets, what have you, it's perfect for
testing any USB power setup but this model is a little nicer in that it is also good
for USB C with its higher current and voltage capabilities - up to 32V and 5A!
If you're using this to test USB C be sure to get a cable with E-Mark power
negotiation chips inside so you get the proper current and voltage out - many
cheap USB C cables skip this part and won't work well for high-current/voltage
charging.
TECHNICAL DETAILS
Tester Dimensions: approx 68 x 60mm / 2.6" x 2.3"
Voltage Range: 3.6V~32V
Current Range: 0~5.1A
https://www.adafruit.com/product/4232/6‐10‐19
很抱歉,暂时无法提供与“4232”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+224.221181+28.96763
