4237
4237
    ADAFRUIT
    LITHIUM ION POLYMER BATTERY - 3.
4237 数据手册
    Lithium Ion Polymer Battery with Short Cable - 3.7V 350mAh PRODUCT ID: 4237 Lithium ion polymer (also known as 'lipo' or 'lipoly') batteries are thin, light and powerful. The output ranges from 4.2V when completely charged to 3.7V. This battery has a capacity of 350mAh for a total of about 1.3 Wh. If you need a larger (or smaller!) battery, we have a full range of LiPoly batteries The batteries come pre-attached with a genuine 2-pin JST-PH connector as shown and include the necessary protection circuitry. Because they have a genuine JST connector, not a knock-off, the cable wont snag or get stuck in a matching JST jack, they click in and out smoothly. The included protection circuitry keeps the battery voltage from going too high (over-charging) or low (over-use) which means that the battery will cut-out when completely dead at 3.0V. It will also protect against output shorts. However, even with this protection it is very important that you only use a LiIon/LiPoly constant-voltage/constant-current charger to recharge themand at a rate of 350mA or less. We suggest our Micro Lipo charger, which has a 100mA default rate. Like most lipos, the batteries we sell do not have thermistors built in. This is why we suggest charging at 1 C or even less - 100 to 350mA is a good rate, and available from any USB port if using a USB-powered charger Additional safety notes: Do not use a NiMH/NiCad/lead-acid charger! Also, do not abuse these batteries, do not short, bend, crush or puncture. Never charge or use unattended. Always inspect batteries and surrounding circuitry constantly for any damage, loose wiring, or possibility of short circuits. Polarity matches all Adafruit LiPoly/LiIon chargers and boards, other brands may have reverse polarity and can destroy your battery. As with all Lithium ion polymer batteries and with any power source - they should be used by experts who are comfortable working with power supplies. TECHNICAL DETAILS Details:  Weight: 9g  Size: 55mm x 25mm x 3.0mm  Power Lead Length: 25mm  Output: 350mAh at 3.7V nominal Product Dimensions: 55.0mm x 25.0mm x 3.0mm / 2.2" x 1.0" x 0.1"   https://www.adafruit.com/product/4237/6‐13‐19
很抱歉,暂时无法提供与“4237”相匹配的价格&库存,您可以联系我们找货
