Heat-Set Insert For Soldering Irons - #440 / M3 Inserts
PRODUCT ID: 4239
Wanna improve the connection strength between your project's 3D-printed
parts, and also have nice clean surfaces? Instead of gluing bits together, or
screwing plastic screws directly into your 3D prints, use strong and reusable
machine screws and heat-set inserts. Heat set inserts are only a few cents a
piece and have a grooved outside, with theads on the inside. Originally they
were designed for injection molded parts but they work fabulously for 3D
printed plastic as well.
If you have tried to set heat-set inserts in your plastic or 3D printed part with
your soldering iron, you may have had the frustration of pushing the insert in
only to have it come right back out stuck to your soldering iron and ruining your
part in the process. Most soldering iron tips can catch on the rim of the insert
causing it to stick on the iron when you pull the iron out. If you use the
"horizontal method" it's hard to know the insert is straight. These insert tips
have a vertical wall that solves that problem. The iron pulls right out after
pressing the hot insert. Because the shoulder is square it's easier to know if the
insert is square in the piece, something that's harder to control with a conical
soldering tip.
All you need is a soldering iron that takes Hakko tips (which nearly all the irons
we stock do). Instead of a soldering tip, attach this specially-turned part. Heat
up the iron and use it to press the insert in, wait for it to cool, then use like a
hex nut that's embedded inside the plastic.
Check out this video from Noe & Pedro that shows you how to do it
This tip is for use with #4-40 or M3 sized inserts. Soldering iron not
included, we have lots you can pick from, any that use Hakko tips will do the
job. No inserts are included - pick up some here!
TECHNICAL DETAILS
Insert diameter: 2.1mm
https://www.adafruit.com/product/4239/6‐6‐19
很抱歉,暂时无法提供与“4239”相匹配的价格&库存,您可以联系我们找货
