Brass Heat-Set Inserts for Plastic - M3 x
4mm - 50 pack
PRODUCT ID: 4255
Wanna improve the connection strength between your project's 3D-printed
parts, and also have nice clean surfaces? Instead of gluing bits together, or
screwing plastic screws directly into your 3D prints, use strong and reusable
machine screws and heat-set inserts. Heat set inserts are only a few cents a
piece and have a grooved outside, with theads on the inside. Originally they
were designed for injection molded parts but they work fabulously for 3D
printed plastic as well.
You could use a plain soldering iron to try to heat-press these in - Heat up the
iron and use it to press the insert in, wait for it to cool, then use like a hex nut
that's embedded inside the plastic. We strongly recommend our heat-set insert
tool for soldering irons because it's really hard to insert them straight otherwise
and you risk damaging your print!
Check out this video from Noe & Pedro that shows you how to do it
Comes as a 50 pack of M3-threaded inserts that are 4mm long.
https://www.adafruit.com/product/4255/6‐12‐19
很抱歉,暂时无法提供与“4255”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+56.446471+7.27907
