4253
4253
    ADAFRUIT
    带镀层通孔 Protoboard 羽毛 平台评估扩展板
4253 数据手册
        Adafruit Quad 2x2 FeatherWing Kit with Headers PRODUCT ID: 4253   This is the FeatherWing Quad 2x2 - a prototyping add-on and more for all Feather boards. This is similar to our FeatherWing Proto except there are four! The magic of the Quad comes when you want to connect your Feather to three other Feather Wings without needing any stacking headers. The boards are all set up in a 2x2 grid, thus the name The Quad comes with:  1 Quad 2x2 Wing PCB  4 sets Feather Female Headers The Quad, like the Proto, has three breakouts for each pin on a Feather, as well as a bunch of plain grid proto holes. Also, the four sets of pins are cross connected and for GND and 3.3V, we give you a full strip of connected pads. You'll need to solder on the female headers to the PCB, the Quad comes as a mini kit! We also have a Quad FeatherWing as a side-by-side kit for a slightly different arrangement Check out our range of Feather boards here. TECHNICAL DETAILS  PCB dimensions (unassembled): 103mm x 47mm x 1.6mm             https://www.adafruit.com/product/4253 /6‐13‐19
很抱歉,暂时无法提供与“4253”相匹配的价格&库存,您可以联系我们找货
  • 1+87.819561+11.36181
