USB C Jack to USB A Jack Round Panel
Mount Adapter
PRODUCT ID: 4259
If you need to add a panel-mount connection for USB C, but don't have the time
or tools to cut a custom oval or square hole, this Round Panel Mount Plug is the
easiest and fastest way to panel-ify your project. It's about 30mm in diameter,
so you can drill a hole in your wood, plastic or metal with a common hole-saw
or bit, no special shapes or filing required. Un-screw the plastic nut, insert the
plug and re-attach. Ta-da! Now you have a USB C jack to a USB A jack adapter!
On the 'outer' side is a USB C connection. On the inside is a USB A host
connection. So this is good for when your device doesn't need more than USB
2.0 speeds, and you want to use a flexible USB-to-micro-B cable for the inner
connection but expose a USB C port. In particular, this version is best for use
with USB host devices. If you have a USB client device, check out this USB C to
Micro B panel mount adapter.
It's designed to easily attach to a panel up to 16mm thick (or 0.625"), or as thin
as a few mm. Perfect for adding a USB C port to your project enclosure! We like
this plug in particular for its solid body and 'forgiving' plastic lip that hides the
drill hole.
TECHNICAL DETAILS
Overall length: approx 41mm
Diameter: 30mm
https://www.adafruit.com/product/4259/7‐16‐19
很抱歉,暂时无法提供与“4259”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+52.532531+6.79389
