2.9" Flexible Monochrome eInk / ePaper
Display - 296x128 Monochrome
PRODUCT ID: 4262
Woah, the cyber-future is here! Flexible E-Ink has been demo'd at high tech
events for years but now you can actually get your paws on it. This display is
true E-Ink / E-Paper, once an image is displayed it will stay even once you
remove all power. The image is also high contrast and very daylight readable. It
really does look just like printed paper!
This flexible display sports a 2.9" monochrome (black and white) display. It has
296x128 black ink pixels on a white-ish background. The monochrome displays
also take a lot less time to update, only a couple seconds instead of 15 seconds.
Please note: this display is flexible but that doesn't mean you can constantly
flex it.
These displays should not be flexed/moved during a display update, you'll
get odd effects.
Continuously flexing it will eventually damage the display.
There's no specification for how many times it can be flexed, so keep it
minimal!
We recommend affixing the display to a stable backing to reduce stresses.
E.g. it can be attached to a stiff curved bracelet to make a watch.
Using our CircuitPython or Arduino libraries, you can create a 'frame buffer' with
what pixels you want to have activated and then write that out to the display.
Most simple breakouts leave it at that. But if you do the math, 296 x 128 pixels
= 4.7 KBytes. Which won't fit into many microcontroller memories. Heck, even if
you do have 32KB of RAM, why waste 5KB?
The library we wrote does all the work for you, you can just interface with it as if
it were an Adafruit_GFX compatible display.
Note: This is just the display. You'll want your own eInk Breakout Friend too!
TECHNICAL DETAILS
Dimensions (excluding ribbon cable): 80 x 37 x 0.25mm
https://www.adafruit.com/product/4262 /6‐13‐19
很抱歉,暂时无法提供与“4262”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+465.10200
- 200+185.58720
