4299
4299
    ADAFRUIT
    MICRO B USB TO USB C ADAPTER
4299 数据手册
        Micro B USB to USB C Adapter PRODUCT ID: 4299 As technology changes and adapts, so does Adafruit, and speaking of adapting, this adapter has a Micro B USB jack and a USB C plug. USB C is the latest industry-standard connector for transmitting data and power. Like Lightning and MagSafe cables, USB C has no up or down orientation. Since it uses a new connector, you may have lots of cables and power supplies that are hanging around with micro B connectors. Instead of throwing those out, up- cycle them! Plug this adapter onto the end of a micro B cable and now it's a USB C. Works great with any device that has a USB C port, especially the Raspberry Pi 4 so that you can continue to use our sturdy 2.5A 5V power plugs! These adapters don't magically give you USB C speeds if you are using a USB 2.x port, and they won't give you the power negotiation stuff because your computer doesn't have that built in. So it's strictly for devices that use 5V and up to 2.5A. TECHNICAL DETAILS Dimensions: 20 x 10.7 x 4.9mm                   https://www.adafruit.com/product/4299/7‐16‐19
很抱歉,暂时无法提供与“4299”相匹配的价格&库存,您可以联系我们找货
