4305
4305
    ADAFRUIT
    SLICE MINI CUTTER WITH CERAMIC B
4305 数据手册
  Slice Mini Cutter with Ceramic Blade PRODUCT ID: 4305 Cut through cardboard like a boss with the Slice Mini Cutter, a safer cutter with a ceramic blade. This handheld tool is way better than using scissors or a box cutter, and its a lot harder to cut yourself by accident than metal blades (please don't try to cut yourself, you will eventually succeed!) Ceramic blades are much safer than metal blades and are longer lasting than steel. This is the perfect mini-tool for cardboard-crafting-trashbot enthusiasts! Ever get annoyed when the blade gets stuck to tape or adhesive? The Mini Cutter's ceramic blade takes that problem out of the equation. Perfect size for toting around in your pocket or zipper case! Features  Installed blade type: rounded tip  Automatic spring-loaded retraction for added safety  Ambidextrous design: Switch blade slots for southpaws  Finger-friendly blade cuts effectively  Non-sparking, non-conductive, non-magnetic blade  Chemically inert blade never rusts  Oil- and lubricant-free blade  100% zirconium oxide blade  Blade edge last up to 11.2x longer than metal  No-tool blade change Note: Mini Cutter is compatible only with Slice safety blades, #10404 and #10408. https://www.adafruit.com/product/4305/7-26-19
很抱歉,暂时无法提供与“4305”相匹配的价格&库存,您可以联系我们找货
