4307
4307
    ADAFRUIT
    SLICE AUTO-RETRACTABLE PEN CUTTE
4307 数据手册
  Slice Auto-Retractable Pen Cutter with Ceramic Blade PRODUCT ID: 4307 Cut through cardboard like a boss with the Slice Auto-Retractable Pen Cutter, a safer cutter with a ceramic blade. This handheld tool is way better than using scissors or a box cutter, and it's a lot harder to cut yourself by accident than metal blades (please don't try to cut yourself, you will eventually succeed!) Ceramic blades are much safer than metal blades and are longer lasting than steel. This is the perfect pen cutter for cardboard-crafting-trashbot enthusiasts! The pen cutter's slim profile and handle shape make it ideal for hard-to-reach spots that need a lil' more maneuverability. It makes easy work out of cutting materials such as fiberglass, clamshell packaging, and adhesive vinyl. Ever get annoyed when the blade gets stuck to tape or adhesive? This ceramic blade takes that problem out of the equation. Features  Handle type: auto-retractable  Handle features rubberized slider button  Compatible blades: 10404, 10408  Cut depth: 11mm  Finger-friendly edge stays sharp 11x longer  Non-sparking, non-conductive blade  Durable glass-filled nylon handle  Ambidextrous design  Rust-free blade  No-tool blade change  Lanyard hole keeps tool handy  Fewer blade changes = fewer injuries Note: Auto-Retractable Pen Cutter is compatible only with Slice safety blades, #10404 and #10408. https://www.adafruit.com/product/4307/7-26-19
很抱歉,暂时无法提供与“4307”相匹配的价格&库存,您可以联系我们找货
