Grove Shield FeatherWing for all Feathers
- Wio Lite
PRODUCT ID: 4357
The Grove Shield FeatherWing for Particle Mesh and all Feathers is an add-under
for any Particle Mesh or Feather board, so that you can easily interface with
Seeed's huge collection of Grove sensors. Now you can have full range of
hundreds of Grove modules with Particle Mesh along with our Feather line!
Working with Grove requires no soldering. Just plug the sensors, actuators, or
displays into this shield via a Grove cable (not included), so you can focus on
coding and making!
You get 10 Grove connectors on this shield, including:
4 Grove analog connectors, 2 analog pins each, 5 analog pins in total
(they're in pairs)
4 Grove digital connectors, 2 digital pins each, 5 digital pins in total
(they're in pairs)
1 Grove I2C connector (these will also fit our 4-pin STEMMA connectors)
1 Grove UART connector (RX and TX)
This board has an unusual power supply setup where it disables the ENable on
the 3.3V regulator and then has a buck converter to generate the 3.3V from
VBAT or VUSB based on the switch. This should work with all our Feathers but it
is a little odd because usually the 3.3V power supply is not separately-powered.
Please note that this board was designed for Feathers with our Feather 32u4 /
M0 / M4 / nRF52840 / etc pin numbering! So the pin numbers next to each
Grove connector match the pin numbering used on those Feathers. That is, after
the I2C pins, the pins go D5, D6, D9, D10, D11 in that order.
If you're using other Feather boards, and only using the UART (RX/TX), I2C
(SDA/SCL) or analog pins (A0-A5), the numbering will match up just fine since
that's the same on pretty much all Feather boards (some, like the ESP8266, don't
have A1-A5 pins). But for the digitalconnectors, you'll need to look and match
the pin numbers from the Feather you've got to the Grove connects since some
Feathers have different digital pin numbering. Or use a multimeter to verify
connectivity. It's not a big deal as long as you know to watch out for it, and it
only affects the 4 digital connectors.
TECHNICAL DETAILS
Operating voltage: 3.3 / 5V
Operation Temperature: -25℃ to +85℃
Analog Ports: 4
Digital Ports: 4
UART Ports: 1
I2C Ports: 1
10 Grove Ports
Power Mode Switch: If you use USB to power your Feather board, select the
5V mode. If you use the LiPoly battery, select the VBAT mode.
Extra Female Pin Headers
Seeed Studio Wiki
Product Dimensions: 60.0mm x 52.0mm x 11.5mm / 2.4" x 2.0" x 0.5"
Product Weight: 19.6g / 0.7oz
https://www.adafruit.com/product/4357/9‐11‐19
很抱歉,暂时无法提供与“4357”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+63.272191+8.17861
