4364
4364
    ADAFRUIT
    缆线组件 矩形 6 针插头转 USB C 公插头 3.28'(1.00m)
4364 数据手册
FTDI Serial TTL-232 USB Type C Cable 5V Power / 3.3V Logic PRODUCT ID: 4364 Just about all electronics use a UART serial port with RX and TX pins for debugging, bootloading, programming, serial output, etc. But it's rare for a computer to have a serial port anymore. Thus, a serial cable is an essential part of any electrical engineer's toolkit. This is a USB C to TTL serial cable with an FTDI FT232R usb/serial chip embedded in the head. It has a 6-pin socket at the end with 5V power and ground, and 3.3V logic (5V compatible) RX, TX, RTS and CTS. Useful whenever you want to communicate with a TTL serial device such as an Arduino Pro Mini or ESP breakout, and the pinout will match up exactly to any 'FTDI' 6-pin header. The version we have is the 5V Power / 3V Logic. The data signals are at 3V output and the power line provides 5V. The logic pins are 5V-friendly so we suggest this for any product that needs FTDI cables and has 5V power usage or is 3V-logic friendly. If you have a device that is running at 5V logic and power, this cable will work fine. If you want to tweak the voltages and signals a little, you should also check out the FTDI friend. We also carry a 3V Power / 3V Logic FTDI Cable. TECHNICAL DETAILS • Cable length: 1 meter • 28AWG • Pin Wiring: • Black - GND • Brown - CTS • Red - VCC 5V @ 500mA • Orange - TXD 3V logic level • Yellow - RXD 3V logic level • Green - RTS Revision History: • As of Feb 10, 2020, we've updated this from a 5V Power / 5V Logic to a 5V Power / 3V Logic • Datasheet https://www.adafruit.com/product/4364/9-2-21
很抱歉,暂时无法提供与“4364”相匹配的价格&库存,您可以联系我们找货
