Small -1 Amp to +1 Amp DC Current
Analog Panel Meter
PRODUCT ID: 4404
Analog panel meters are arguably not as blingy or flashy as LEDs, but their
simplicity adds a touch of elegance and makes them easier to read quickly.
This Small -1 Amp to +1 Amp DC Current Analog Panel Meter is handheld-
size, with three screws to open up the panel and replace the backing paper, if
you like.
Great for measuring larger bidirectional current draws, perhaps to and from a
battery bank or generator. Of course you can use it just fine with uni-directional
current draw as well, either positive or negative currents.
The back is constructed with two bolts the left coil is marked below with
Negative to distinguish the positive from the negative. You can wrap a wire
around the bolt and use the nuts to keep them in place, or use alligator clips.
TECHNICAL DETAILS
Panel Dimensions: ~60mm x 55mm x 10mm
https://www.adafruit.com/product/4404/1‐13‐20
很抱歉,暂时无法提供与“4404”相匹配的价格&库存,您可以联系我们找货
