Monochrome 0.91" 128x32 I2C OLED
Display - STEMMA QT / Qwiic Compatible
PRODUCT ID: 4440
These displays are small, only about 1" diagonal, but very readable due to the
high contrast of an OLED display. This display is made of 128x32 individual
white OLED pixels, each one is turned on or off by the controller chip. Because
the display makes its own light, no backlight is required. This reduces the power
required to run the OLED and is why the display has such high contrast; we
really like this miniature display for its crispness!
To make life easier so you can focus on your important work, we've taken the
OLED display and put it onto a breakout PCB along with support circuitry to let
you use this little wonder with 3.3V (Feather/Raspberry Pi) or 5V (Arduino/
Metro328) logic levels.
We've updated the design to add auto-reset circuitry so that the reset pin is
optional, since it speaks I2C you can easily connect it up with just two wires
(plus power and ground!). We've even included SparkFun
qwiic compatible STEMMA QT connectors for the I2C bus so you don't even need
to solder!
Just wire up to your favorite micro and read through our detailed tutorial with
both Arduino and Python/CircuitPython libraries for text and graphics. You'll
need a microcontroller with more than 512 bytes of RAM since the display must
be buffered.
The power requirements depend a little on how much of the display is lit but on
average the display uses about 20mA from the 3.3V supply. Built into the OLED
driver is a simple switch-cap charge pump that turns 3.3v-5v into a high
voltage drive for the OLEDs, making it one of the easiest ways to get an OLED
into your project!
Please note that OLED displays are made of hundreds of...OLEDs! That means
each pixel is a little organic LED, and if it's kept on for over 1000 hours it'll start
to dim. If you want to keep the display uniformly bright, please turn off the
display (set the pixels off) when it isn't needed to keep them from dimming.
TECHNICAL DETAILS
Dimensions:
PCB: 20mm x 35mm (0.8" x 1.4")
Display area: 7mm x 25mm
Thickness: 4mm
Display details:
Diagonal Screen Size:0.91"
Number of Pixels:128 × 32
Color Depth:Monochrome (White)
Module Construction:COG
Module Size (mm):46.30× 11.50 × 1.45
Panel Size (mm):30.00 × 11.50 × 1.45
Active Area (mm):22.384 × 5.584
Pixel Pitch (mm):0.175 × 0.175
Pixel Size (mm):0.159 × 0.159
Duty:1/32
Brightness ( cd/m2):150 (Typ) @ 7.25V
Interface:I2C
Display current draw is completely dependent on your usage: each OLED
LED draws current when on so the more pixels you have lit, the more
current is used. They tend to draw ~15mA or so in practice but for precise
numbers you must measure the current in your usage circuit.
This board/chip uses I2C 7-bit address 0x3C
https://www.adafruit.com/product/4440/11‐25‐19
很抱歉,暂时无法提供与“4440”相匹配的价格&库存,您可以联系我们找货
