4449
4449
    ADAFRUIT
    USB A JACK TO 30CM FEMALE JUMPER
4449 数据手册
      USB Type A Jack Breakout Cable with Premium Female Jumpers - 30cm long PRODUCT ID: 4449 If you'd like to connect a USB-host-capable chip to your USB peripheral, this cable will make the task very simple. There is no converter chip in this cable! It's basically a plain USB cable that's cut in half and with jumper sockets on the power and data lines. Simple to use, does the job when you have something that exposes the D+/D- pins.  Red wire connects to 5V power (to the USB device)  Black wire connects to common data/power ground  White connects to D+ data positive  Green connects to D- data negative Remember, this has no USB-Serial converter inside it! It's for direct connection to a USB interface, only. TECHNICAL DETAILS  Length: 30cm  28AWG           https://www.adafruit.com/product/4448/1‐27‐20
很抱歉,暂时无法提供与“4449”相匹配的价格&库存,您可以联系我们找货
  • 1+17.160151+2.21967
