4468
4468
    ADAFRUIT
    风扇 管轴式 5VDC 方形 - 30mm 长 x 30mm 高 2 位置矩形连接器
4468 数据手册
      Miniature 5V Cooling Fan with Molex PicoBlade Connector PRODUCT ID: 4468 Looking for another way to keep your project cool? Hook up this 5V Mini Cooling Fan and prevent from overheating! Of course, it's also great for use with any small computer or FPGA or motor driver or anything that needs cooling. We also carry a mini 5V cooling fan with regular JST 2-pin connectors. This fan is nearly identical - it has the same fan body, but the cable has a handy "Molex PicoBlade" 1.25mm pitch 2pin cable, which makes plugging into a board easy. Or you can cut off the connector and just solder/clamp onto the wires directly. TECHNICAL DETAILS Specifications:  Operating voltage: 5V  Current: 0.2 A  Brushless DC fan  Fan dimensions: 30mm x 30mm x 8mm  Molex PicoBlade connector  Mounting screws & nuts included https://www.adafruit.com/product/4468/2‐10‐20
很抱歉,暂时无法提供与“4468”相匹配的价格&库存,您可以联系我们找货
  • 1+27.569621+3.45729
库存:164
