4517
4517
    ADAFRUIT
    LIS3MDL,LSM6DSOX 加速计,陀螺仪,磁力计 传感器 STEMMA QT 平台评估扩展板
4517 数据手册
    Adafruit LSM6DSOX + LIS3MDL Precision 9 DoF IMU - STEMMA QT / Qwiic PRODUCT ID: 4517 Add high quality motion, direction and orientation sensing to your Arduino project with this all-in-one 9 Degree of Freedom (9-DoF) sensor with sensors from ST. This little breakout contains two chips that sit side-by-side to provide 9 degrees of full-motion data. The board includes an LSM6DSOX, a 6-DoF IMU accelerometer + gyro. The 3axis accelerometer can tell you which direction is down towards the Earth (by measuring gravity) or how fast the board is accelerating in 3D space. The 3-axis gyroscope can measure spin and twist. This new sensor from ST has very low gyro zero rate and noise, compared to the MPU6050 or even LSM6DS33 so it's excellent for orientation fusion usage: you'll get less drift and faster responses. The LSM6DSOX has flexible data rates and ranges. For the accelerometer: ±2/±4/±8/±16 g at 1.6 Hz to 6.7KHz update rate. For the gyroscope: ±125/±250/±500/±1000/±2000 dps at 12.5 Hz to 6.7 KHz. There's also some nice extras, such as built in tap detection, activity detection, pedometer/step counter and a programmable finite state machine / machine learning core that can perform some basic gesture recognition. It also includes a LIS3MDL 3-axis magnetometer that can sense where the strongest magnetic force is coming from, generally used to detect magnetic north. The three triple-axis sensors add up to 9 degrees of freedom, by combining this data you can orient the board. Check out our guide on how to do that! To make getting started fast and easy, we placed the sensors on a compact breakout board with voltage regulation and level-shifted inputs. That way you can use them with 3V or 5V power/logic devices without worry. To make usage simple, we expose only the I2C interface and some interrupt pins from each chip. The breakout comes fully assembled and tested, with some extra header so you can use it on a breadboard. Four mounting holes make for a secure connection. Additionally, since it speaks I2C you can easily connect it up with two wires (plus power and ground!). We've even included SparkFun qwiic compatible STEMMA QT connectors for the I2C bus so you don't even need to solder! Just wire up to your favorite micro like the STM32F405 Feather with a plug-and-play cable to get 9 DoF data ASAP. You can change the I2C addresses on the back using the solder jumpers, to have two of these sensor boards on one bus. We also wrote libraries to help you get these sensors integrated with your Arduino/C++. This library covers the accel/gyro and this library is for the magnetometer. For advanced Arduino usage, ST has their own fully-featured library that includes extras such as FIFO management and tap detection for the LSM6DSOX and also for the LIS3MDL magnetometer. TECHNICAL DETAILS LSM6DSOX Specifications:  Accelerometer ±2/±4/±8/±16 g at 1.6 Hz to 6.7KHz update rate  Gyroscope: ±125/±250/±500/±1000/±2000 dps at 12.5 Hz to 6.7 KHz  Continuous and single-conversion modes  Advanced pedometer, step detector and step counter  Significant Motion Detection, Tilt detection  Standard interrupts: free-fall, wakeup, 6D/4D orientation, click and double-click  Programmable finite state machine: accelerometer, gyroscope and external sensors  Machine Learning Core  I2C Address 0x6A or 0x6B LIS3MDL Specifications:  ±4/±8/±12/±16 gauss selectable magnetic full scales  Continuous and single-conversion modes  16-bit data output  Interrupt generator  I2C Address 0x1C or 0x1E            https://www.adafruit.com/product/4517/3‐23‐20
很抱歉,暂时无法提供与“4517”相匹配的价格&库存,您可以联系我们找货
