4520
4520
    ADAFRUIT
    智能,智慧,发光二极管,图形 TFT - 彩色 1.3"(33.02mm) 240 x 240
4520 数据手册
      Adafruit 1.3" 240x240 Wide Angle IPS TFT Display PRODUCT ID: 4520 DESCRIPTION This is a screen for advanced hackers who like the look of the TFT screen we've put into the Adafruit CLUE and Adafruit Mini PiTFT 1.3". The 1.3" display has 240x240 16-bit fullcolor pixels and is an IPS display, so the color looks great up to 80 degrees off-axis in any direction. The TFT driver (ST7789) is very similar to the popular ST7735, and our Arduino library supports it well. This is just the display module! No PCB is included! We're selling this module bare for those who want to integrate it into their own project. If this is your first time working with this TFT we suggest our breakout board which makes it easy to use SPI interfacing and also has mounting holes, level shifting, etc.. Of course, we wouldn't just leave you with a datasheet and a "good luck!" - we've written a full open-source graphics library that can draw pixels, lines, rectangles, circles, text, and bitmaps as well as example code and a wiring tutorial. The code is written for Arduino but can be easily ported to your favorite microcontroller! For the matching connector, you'll need a 24-pin 0.5mm pitch bottom contact FPC connector such as Amphenol SFV24R-2STE1HLF TECHNICAL DETAILS  Screen dimensions: 26mm x 26mm / 1.02" x 1.02"                                          https://www.adafruit.com/product/4520/2‐28‐20
4520
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40至85摄氏度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低噪声特性。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装形式。
很抱歉,暂时无法提供与“4520”相匹配的价格&库存,您可以联系我们找货
