50-pin 0.5mm FFC / FPC Extender
PRODUCT ID: 4522
DESCRIPTIONThis 50-pin FFC / FPC Extender is very
simple. It lets you connect two 50-pin
0.5mm pitch FFC (Flexible Flat Cable) /
FPC (Flexible Printed Circuit) cables endto-end and extend the length.
Note that pin 1 of one cable is connected
to pin 50 of the other so you need to use a
cable that has contacts on the same side
(type A cable)
Carefully pry the two ears of the
connectors, plug the cables with contacts
pointing up, and then push the ears back
in for a solid connection.
We also carry a 40-pin 0.5mm version and
a 24-pin 0.5mm version.
https://www.adafruit.com/product/4522/5‐27‐20
很抱歉,暂时无法提供与“4522”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+21.09240
- 200+8.16480
- 500+7.87320
- 1000+7.73280
