24-pin 0.5mm FFC / FPC Extender
PRODUCT ID: 4524
DESCRIPTIONThis 24‐pin FFC / FPC Extender is very simple. It lets you connect two 24‐pin
0.5mm pitch FFC (Flexible Flat Cable) / FPC (Flexible Printed Circuit) cables end‐to‐
end and extend the length.
Note that pin 1 of one cable is connected to pin 24 of the other so you need to use a
cable that has contacts on the same side (type A cable)
Carefully pry the two ears of the connectors, plug the cables with contacts pointing
up, and then push the ears back in for a solid connection.
We also carry a 40-pin 0.5mm version and a 50-pin 0.5mm version.
https://www.adafruit.com/product/4524/5‐27‐20
很抱歉,暂时无法提供与“4524”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+17.36640
- 200+6.72840
- 500+6.49080
- 1000+6.37200
- 国内价格 香港价格
- 1+8.391781+1.08570
