4528
4528
    ADAFRUIT
    4 矩形电缆组件 插口至插口 0.328'(100.00mm,3.94")
4528 数据手册
    Grove to STEMMA QT / Qwiic / JST SH Cable - 100mm long PRODUCT ID: 4528 Are you a maker in the midst of a STEMMA dilemma? This 100mm long cable is a fantastic chimera-cable fitted with STEMMA QT / Sparkfun Qwiic JST SH on one end, and a Grove connector on the other. This cable can be used with STEMMA or STEMMA QT / Qwiic boards to easily connect sensors and drivers from one board to the other. Please note you will have to watch for voltages on the power/signal pin when using 3V-only Qwiic sensors with this cable!  You can use this to connect any Grove I2C sensor (3-5V) to an I2C host with Stemma QT or Qwiic connectors (3V)  You can use this to connect any STEMMA QT (3-5V) sensor to Grove or STEMMA host (5V) board, and vice versa  Warning: If you want to connect a Qwiic board (3V power only!) to a Grove or STEMMA host, make sure the power switch is set to 3V The colors are:  Black for GND  Red for V+ - For Qwiic boards, 3.3V. For STEMMA QT, 3 to 5V.  Blue for SDA  Yellow for SCL For more information on JST, visit their website. Check out all our STEMMA QT offerings here including a wide range of lengths and connectors TECHNICAL DETAILS       https://www.adafruit.com/product/4528/3‐11‐20
很抱歉,暂时无法提供与“4528”相匹配的价格&库存,您可以联系我们找货
    库存:50
