4539
4539
    ADAFRUIT
    无焊剂试验电路板 端子条(无框架) 3.20" 长 x 2.10" 宽(81.3mm x 53.3mm)
4539 数据手册
      Half-Size Breadboard with Mounting Holes PRODUCT ID: 4539 This cute 3.2″ × 2.1″ (82 × 53mm) solderless half-size breadboard has four bus lines and 30 rows of pins, our favorite size of solderless breadboard for projects. You get a whoppin' 400 tie points! Plug in a Feather or Metro Mini with the rest for sensors or buttons or even a little display. You can pull the power rails off easily to make the breadboard as thin as 1.4" (3.5cm). You can also cut these in half with a saw to create 2 tiny breadboards, or "snap" these breadboards together either way to make longer and/or wider breadboards. The board also has an adhesive backing and 8 mounting holes for M2 or #2 screws on a 1 cm pitch. This makes it super easy to mount the breadboard to a chassis for your next robot friend! (Just be sure to grab some M2 standoffs and/or screws) Note that you'll need an awl/screwdriver/tweezers to pop a hole thru the thin foam backing. Dimensions:  3.2″ × 2.1″ (82 × 53mm)  Weight: 36g   https://www.adafruit.com/product/4539/4‐7‐20
很抱歉,暂时无法提供与“4539”相匹配的价格&库存,您可以联系我们找货
