4553
4553
    ADAFRUIT
    FLIRC ALUMINUM CASE FOR RPI 4
4553 数据手册
      Flirc Aluminum Case for Raspberry Pi 4 PRODUCT ID: 4553 We dig the sleek lines and satisfying heft of this aluminum case. Handsomely designed and thoughtfully constructed with a built-in heat sink, this Flirc enclosure boasts both form and function. The sides are aluminum, and the top and bottom are soft silicone for a nice and easy-to-clean case that looks great next to your A/V system. Included are rubber feet to raise the enclosure so it hovers underneath your Pi. In addition to the heat sink, small ventilation slots on the bottom help keep the Raspberry Pi running cool. GPIO pins are accessible through the slot on the bottom of the case, and there is no need to disassemble to get to the SD card. Note: Does not include Raspberry Pi 4 computer. We also carry aluminum cases for Pi 4 with and without fans. TECHNICAL DETAILS  Assembled dimensions (L x H x W): 66mm x 91.4mm x 25.4mm / 2.6" x 3.6" x 1"   https://www.adafruit.com/product/4553/3‐23‐20
很抱歉,暂时无法提供与“4553”相匹配的价格&库存,您可以联系我们找货
