DIN Rail Terminal Block Adapter to
Grand Central or Arduino Mega
PRODUCT ID: 4555
DESCRIPTION
This one's going out to all the makers and designers who use DIN railing in their
builds. This adapter plate is perfect for simplifying complex wiring. You connect
an Arduino Mega or Grand Central M4 Express to this breakout PCB, which can
be DIN rail-mounted. All wires are broken out into terminal blocks, so you can
connect and power your sensors, displays, microcontrollers, etc.
No soldering required! Place the microcontroller face-down onto the headers,
unscrew the terminal blocks, and slide in your stranded or solid-core wire.
Note: DIN Rail and microcontroller are not included.
TECHNICAL DETAILS
Overall dimensions (W x L x H): 153mm x 87mm x 45mm
PCB Dimensions (W x L): 150mm x 72.5mm
Pitch: 3.81mm/0.15" screw terminal block
Terminal block wire range: 26-16AWG, strip length 5mm, M2 slotted
screw
Diagram https://cdn‐shop.adafruit.com/product‐files/4555/4555‐diagram.png
Pinout Diagram https://cdn‐shop.adafruit.com/product‐files/4555/4555‐pinout.png
https://www.adafruit.com/product/4555/3‐23‐20
很抱歉,暂时无法提供与“4555”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+487.308131+60.64038
