4556
    ADAFRUIT
    Arduino板或其他MCU板 - 安装套件
4556 数据手册
    DIN Rail Terminal Block Adapter to Metro or Arduino Uno PRODUCT ID: 4556 DESCRIPTION This one's going out to all the makers and designers who use DIN railing in their builds. This adapter plate is perfect for simplifying complex wiring. You connect an Arduino Uno or Adafruit Metro to this breakout PCB, which can be DIN rail- mounted. All wires are broken out into terminal blocks, so you can connect and power your sensors, displays, microcontrollers, etc. No soldering required! Place the microcontroller face-down onto the headers, unscrew the terminal blocks, and slide in your stranded or solid-core wire. Note: DIN Rail and microcontroller are not included. TECHNICAL DETAILS  Overall dimensions (W x L x H): 83mm x 87mm x 45mm  PCB Dimensions (W x L): 80mm x 72.5mm  Pitch: 3.81mm/0.15" screw terminal block  Terminal block wire range: 26-16AWG, strip length 5mm, M2 slotted screw Dimensional Drawing https://cdn‐shop.adafruit.com/product‐files/4556/4556‐dimensional%20drawing.png  Pinout Diagram   https://cdn‐shop.adafruit.com/product‐files/4556/4556‐pinout.png      https://www.adafruit.com/product/4556/3‐23‐20
很抱歉,暂时无法提供与“4556”相匹配的价格&库存,您可以联系我们找货
