MPM3610 3.3V Buck Converter Breakout
- 21V In 3.3V Out at 1.2A
PRODUCT ID: 4683
This little buck converter based on the MPM3610 is a marvel, taking up to 21V
input and providing a 3.3V output with up to 1.2A current. It's great for
supplying power to popular 3.3V voltage circuits from a range of battery or
power options. This chip provides up to 1.2 Amp load current across the entire
input voltage range of 4.5 to 21V. The high voltage range is what sets this buck
converter apart from most, as many converters max out at ~6 VDC input.
Great for your portable project, we made this "pin compatible" with the LM1117 3.3V TO-220 chip so you can swap it in for better performance (90-95%
efficiency!) There's also an ENable pin, tie it low to shut down the output
completely.
The Adafruit MPM3610 Breakout runs at 2-MHz fixed-frequency in PWM mode the fully integrated inductor design is efficient and very small!
Comes with a fully assembled and tested breakout board. We also include
header to plug it into a breadboard.
TECHNICAL DETAILS-
PCB Files in EagleCAD format
Fritzing object available in Adafruit Fritzing Library
MPM3610 Product Page
Product Dimensions: 17.0mm x 10.0mm x 3.3mm / 0.7" x 0.4" x 0.1"
Product Weight: 0.5g / 0.0oz
https://www.adafruit.com/product/4683/8-31-20
很抱歉,暂时无法提供与“4683”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+56.818771+7.35038
