4686
4686
    ADAFRUIT
    TMP235 温度 传感器 STEMMA 平台评估扩展板
4686 数据手册
    Adafruit TMP235 - Plug-and-Play STEMMA Analog Temperature Sensor - TMP235 PRODUCT ID: 4686 DESCRIPTION For fans of the TMP36, we now have a very similar analog temperature sensor with a 3-pin JST connector (we call these STEMMA connectors). Unlike many of our temperature sensors, this one is analog output, not I2C, so its best used by a microcontroller with an analog input, as most microcontrollers do. These sensors are very simple to use, no libraries or complex configurations required. Plug this board into any of our 3-pin JST PH cables (we have ones with header ends, alligator clips, etc) Red goes to 3V to 5V DC power, black wire connects to ground, and white wire connects to an analog input. The voltage out is 0V at -50°C and 1.75V at 125°C. You can easily calculate the temperature from the voltage in millivolts: Temp °C = 100*(reading in V) - 50 Like with the TMP36, you'll get the best readings out of an Arduino UNO or compatible if you set the analog reference voltage to external, then connect AREF to 3.3V for a stable analog reference. Please note, a JST PH 3-pin cable is not included but we stock a wide variety with alligator clips, headers, etc. TECHNICAL DETAILS Product Dimensions: 25.5mm x 17.7mm x 7.2mm / 1.0" x 0.7" x 0.3" Product Weight: 2.0g / 0.1oz         https://www.adafruit.com/product/4686/8‐12‐20
很抱歉,暂时无法提供与“4686”相匹配的价格&库存,您可以联系我们找货
