5474
5474
    ADAFRUIT
    连接器套件 适配器
5474 数据手册
30 Piece 5.5 / 2.1mm to DC Barrel Jack Adapter Kit Product ID: 5474 We have a lot of power adapter packs in the shop - from 9V to 12V to 5V we even have an adjustable power supply like one of these. But all of them will come with the same standard 5.5mm / 2.1mm DC barrel jack that is most common on many devices. What if you'd like to power something different, say some old synthesizer or a laptop or some other whats-it? Basically, something that decided 5.5/2.1mm is not available? Here's a handy adapter kit for switching out barrel jack connectors. You get thirty (30!) different barrel jack plug adapters in a wide variety of diameters. Each one plugs in smoothly into a 5.5mm/2.1mm DC jack and provides a different sized tip. There's no voltage translation done here, so you'll need to make sure that the device you're powering is expecting the voltage and current capability of the supply. Great for use with any of our wall wart powered adapters, USB Type C to DC cables, AA battery packs, or USB booster cables. Please note that the tips do not change the polarity: if you have a center positive DC adapter (as almost all are) the tips will also be 'center positive'! Includes: 1. 2.0x0.5mm 2. 3.5x1.1mm 3. 2.35mm 4. 2.5mm 5. 2.5mm (phono jack) 6. 3.5mm (phono jack) 7. 3.0x1.1mm 8. 4.8mm 9. 3.5x1.2mm 10. 4.0x1.7mm (inner spring tip) 11. 4.8x1.7mm (inner spring tip) 12. 5.0mm 13. 5.5x2.5mm 14. 5.5x2.1mm (inner spring tip) 15. 7.9mm (Lenovo Laptop - Round Type) 16. 7.4mm 17. Dell Laptop - Three Contact Type (Latitude C840, Inspiron 3700, Inspiron 3800, Inspiron 8000, Inspiron 1100, Inspiron 5100, etc) 18. 5.5x1.9mm 19. 6.0mm (with center contact pin) 20. 6.3mm 21. 5.5x2.5mm 22. 5.5x2.5 (inner spring tip) 23. 5.5x2.1mm 24. 5.5x2.1mm (inner spring tip) 25. 5.5x1.5mm 26. 5.5x1.7mm (inner spring tip) 27. 5.0x2.1mm 28. 5.0x2.5mm 29. 4.5mm 30. Lenovo Laptop - Large Rectangular Type YouTube link: https://www.youtube.com/watch?t=19&v=AuKynjUTnJc&feature=emb_imp_woyt https://www.adafruit.com/product/5474 10-31-22
很抱歉,暂时无法提供与“5474”相匹配的价格&库存,您可以联系我们找货
