5497
5497
    ADAFRUIT
    2 矩形电缆组件 插口至插头 1.64'(500.00mm)
5497 数据手册
JST-XH Extension Cable - 2.5mm Pitch - 500mm long Product ID: 5497 Description We now have a handy extension cord for JST-XH projects! One end has a JSTXH socket, and the other has a matching plug. Between the two, 500mm of color-coded wire. This solid 2.5mm pitch connector extension cable is great when you need something that can carry a couple amps of current, easy to connect and disconnect, and is just-about 0.1" pitch compatible. The two friction lock for easy-breezy connections whenever you need light and small connectivity. We carry a few different pin configurations for JST XH cables and connectors . Technical Details • All about JST XH connectors https://www.adafruit.com/product/5497 8-17-22
很抱歉,暂时无法提供与“5497”相匹配的价格&库存,您可以联系我们找货
    库存:100
