Step Switch with LED - Three Pack of Green with Red LED - PB86
Product ID: 5518
Description
These hinged momentary step switches are evocative of the 16-step sequencer keys on TR808 sythesizers. Also sometimes used on A/V equipment, they're very tactile with a good
clicky feel. And of course, the built in red LED is great for indicating when something is on
or off - or as visual feedback when clicked.
There's four legs to the switch for mechanical stability. The switch is momentary SPDT type,
there are two pins of the four that act as the common, and they naturally connect to one or
the other of the remaining pins when the button is pressed. Check the diagram below to see
which pins are the pole and which are the two throws. You may also want to use a
multimeter on continuity mode to verify.
Note they are not breadboard or perf-board friendly! You'll need to either hand-wire or
design into a PCB.
The LED is a simple 3mm, 20mA max, 2.1V-forward-voltage, red LED embedded into the
plastic. There is no resistor built in so a 1K or so resistor will be useful to keep the LED
from burning out. Our LED guide will help you on how to pick a resistor - then you can PWM
dim the LED from a microcontroller pin, or connect it to a digital output as desired.
Technical Details
Button dimensions: 17mm x 12mm x 14mm
Diagram
https://www.adafruit.com/product/5518 8-17-22
很抱歉,暂时无法提供与“5518”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+39.710521+5.13762
