AC 166-1 ST/ 3 WS
AC 166-1 ST/ 3 WS
    ADELS
    固态照明连接器 3 位置 插头,公引脚 板至电缆/导线 0.394"(10.00mm) 螺钉
AC 166-1 ST/ 3 WS 数据手册
Connectors System AC 166® Plug and Socket Connectors Tall Version AC 166-1 ST/ 3 white Plug, 3 pole, white, Coding: 1 (Mains), Voltage Rating: 250 V, Current Rating: 16 A, Cross-Section: 2.5 mm², Connection Type: Screw Order Info Reference Number (ref. no.) 160053 Applications Lighting, Installation PU 200 EAN 4028012100682 Type Type Plug Number of poles 3 pole Clamping Units per Pole 1 Colour white Coding 1 (Mains) Cross-Section 2.5 mm² Connection Type Screw PE Function yes Protection Against Incorrect Plugging yes Technical Data Voltage Rating 250 V Current Rating 16 A Insulating Material PA 6.6 Contact Material Brass Core Cross-Section min. 0.5 mm² Core Cross-Section max. 2.5 mm² Impulse Voltage Rating 2.5 kV Flammability Rating V-2 max. Ambient Temperature Operation 200 °C IP Code IP20 IP Code when Plugged IP40 Type of Conductor Solid yes Type of Conductor Flexible yes Type of Conductor Stranded yes Stripping Length 7 mm 07/08/2019 Assembly Contact Screw 0.8x4 / 0.5 Nm 07/08/2019
AC 166-1 ST/ 3 WS 价格&库存
很抱歉,暂时无法提供与“AC 166-1 ST/ 3 WS”相匹配的价格&库存,您可以联系我们找货
