ADT-WDM-LGXMDC-40CH
ADT-WDM-LGXMDC-40CH
    ADTEK(亚德)
    收发器模块 光学 100Gbps 1310nm,1550nm MDC 底座安装
ADT-WDM-LGXMDC-40CH 数据手册
40CH 100G DWDM MDC Module 40CH 100G DWDM MDC Module Product Description The Adtek Dense Wavelength Division Multiplex Module is designed for DWDM network applications. It is based on the AWG technology and operates at 100G channel spacing ITU Grid DWDM wavelengths from 1520nm to 1600nm. Standards Compliance · Telcordia GR-1209-CORE compliant · Telcordia GR-1221-CORE compliant · RoHs-6 compliant www.adtekdata.com 1 40CH 100G DWDM MDC Module Product Features · Low Insertion Loss · High isolation · Low Polarization Dependent Loss · High reliability and high stability Product Specifications Port Configuration Center Wavelength Channel Frequency Channel Space Channel Passband @ 0.5dB Channels Insertion Loss Passband Ripple nm 1X40 nm THz GHz nm dB dB ITU Grid 192.1 to 196.0 100 0.2 ≤5.5 Adjacent Channel Isolation Non-adjacent Channel Isolation Polarization Dependent Loss PMD Return Loss Directivity dB dB dB Ps dB dB Power Handing Operating Temperature Storage Temperature Package Dimension Connector Type mw ℃ ℃ mm - www.adtekdata.com ≤0.5 ≥25 ≥30 ≤0.5 ≤0.5 ≥40 ≥45 ≤300 -5 to 75 -40 to 85 LGX 129*140*28.5 MDC/UPC 2 40CH 100G DWDM MDC Module Mechanical Dimensio Front View Top View www.adtekdata.com 3 40CH 100G DWDM MDC Module About ADTEK Established in 2007, Shenzhen ADTEK Technology Co.,Ltd, located in Shenzhen, is a nation al high-tech enterprise integrating R & D, production, operation and service. The company focuses on providing optical fiber and copper cable connection products fo r global customers, and provides one-stop fiber optic cabling system and network cabling solutions for domestic and foreign operators, telecom main equipment suppliers and sys tem integrators. Our main products cover high-density data centers, 5G fronthaul, OBO onboard connections, FTTX etc. Based on the purpose of "Quality is everything", our products have passed CE, RoHS, UL, FCC and other certifications to ensure the reliability and stability of each product and provide excellent products for our customers. Fiber Optic Patch Cord Fiber Optic Patch Panel WDM AOC Data Center Cabinet Copper Cable Connection Products More Products: https://www.adtekdata.com www.adtekdata.com www.adtekdata.com 4 6
ADT-WDM-LGXMDC-40CH
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光电晶体管输出,6脚光电晶体管负极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为16mA,输出高电平电流为2mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:EL817广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用DIP6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
ADT-WDM-LGXMDC-40CH 价格&库存
很抱歉,暂时无法提供与“ADT-WDM-LGXMDC-40CH”相匹配的价格&库存,您可以联系我们找货
