ADAM-6266-AE
ADAM-6266-AE
    B+BSMARTWORX
    MOD MODBUS TCP RELAY OUTPUT 4-CH
ADAM-6266-AE 数据手册
ADAM-6260 ADAM-6266 6-ch Relay Output Modbus TCP Module 4-ch Relay Output Modbus TCP Module with 4-ch DI ADAM-6260 ADAM-6266 Specifications Relay Output Digital Input ƒƒ Channels ƒƒ Contact Rating (Resistive) ƒƒ Max. Switching Voltage ƒƒ Breakdown Voltage ƒƒ Max. Breakdown Capacity ƒƒ Frequency of Operation ƒƒ ƒƒ ƒƒ ƒƒ Set/Reset Time Mechanical Endurance Isolation between Contact Insulation Resistance ADAM-6260: 5 Form C and 1 Form A ADAM-6266: 4 Form C 250 VAC @ 5A 30 VDC @ 5A 400 VAC 300 VDC 500 VAC (50/60Hz) 1250 VA 360 operations/hour with load 72,000 operations/hour without load 8 ms/8 ms > 15 x 106 operations 1000 Vrms > 10 GΩ @ 500 VDC ƒƒ Channels ƒƒ Dry Contact ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ADAM-6266: 4 Logic 0: Open Logic 1: Closed to DI COM Wet Contact Logic 0: 0 ~ 3 VDC or 0 ~ -3 VDC Logic 1: 10 ~ 30 VDC or -10 ~ -30 VDC (Dry/Wet Contact decided by Switch) Input Impedance 5.2 kW (Wet Contact) Transition Time 0.2 ms Frequency Input Range 0.1 ~ 3kHz Counter Input 3kHz (32 bit + 1 bit overflow) Keep/Discard Counter Value when power off Supports Inverted DI Status Ordering Information ƒƒ ADAM-6260 ƒƒ ADAM-6266 6-ch Relay Output Modbus TCP Module 4-ch Relay Output Modbus TCP Module with 4-ch DI Common Specifications General Features ƒƒ Ethernet ƒƒ LED Indication ƒƒ Protocol ƒƒ Connector ƒƒ Power Input ƒƒ Watchdog Timer ƒƒ Dimensions ƒƒ Protection ƒƒ Power Consumption 2-port 10/100 Base-TX (for Daisy Chain) ADAM-6260: 6 RL ADAM-6266: 4 RL + 4 DI Modbus/TCP, TCP/IP, UDP, HTTP, DHCP, SNMP, MQTT Plug-in 5P/15P screw terminal blocks 10 - 30 VDC (24 VDC standard) System (1.6 seconds) Communication (Programmable) 70 x 122 x 27 mm Built-in TVS/ESD protection Power Reversal protection Over Voltage protection: +/- 35VDC Isolation protection: 2500 VDC ADAM-6260: 4.5 W @ 24 VDC ADAM-6266: 4.2 W @ 24 VDC ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ Daisy chain connection with auto-bypass protection Remote monitoring and control with smart phone/pad Group configuration capability for multiple module setup DI/O LED Indication Flexible user-defined Modbus address. Intelligent control ability by Peer-to-Peer and GCL function Multiple protocol support: Modbus/TCP, TCP/IP, UDP, HTTP, DHCP, SNMP, MQTT ƒƒ Web language support: XML, HTML 5, Java Script ƒƒ System configuration backup ƒƒ User Access Control Environment ƒƒ ƒƒ ƒƒ ƒƒ Operating Temperature -10 ~ 70°C (14 ~ 158°F) Storage Temperature -20 ~ 80°C (-4 ~ 176°F) Operating Humidity 20 ~ 95% RH (non-condensing) Storage Humidity 0 ~ 95% RH (non-condensing) Ethernet I/O Modules: ADAM-6000 All product specifications are subject to change without notice. Last updated: 18-Oct-2017
ADAM-6266-AE 价格&库存
很抱歉,暂时无法提供与“ADAM-6266-AE”相匹配的价格&库存,您可以联系我们找货
