AMT-1023C-DH25
AMT-1023C-DH25
    B+BSMARTWORX
    LED TOUCH MONITOR 23"
AMT-1023C-DH25 数据手册
AMT-1023C-DH25 23" LED Touch Monitor Features ‧Ten point multi-touch ‧High speed USB3.0 hub ‧LED backlight ‧1920 x 1080 resolution ‧Wide viewing angles ‧Windows 8 compatibility ‧HDMI/DVI/VGA interface Introduction AMT-1023C-DH25, 23 inch-wide touch screen, provides a smooth and intuitive touch experience with 1920 x 1080 pixel high definition images and 178⁰(H)/178⁰(V) viewing angles. It supports HDMI, DVI, and VGA interface to be fully compatible with a wide variety of systems. Specifications Model Size Resolution View Angel Display Environment Brightness Color Support Contrast Ratio Response Time Backlight Life Operating Temperature Storage Temperature Humidity Vibration I/O System OSD Power EMC Compliance AMT-1023C-DH25 23" LED 1920 x 1080 178⁰/178⁰ (H) 178⁰/178⁰ (V) 2 250 (cd/m ) 16.7M 1000:1 5 [msec] 30,000 (hrs) 0~40°C -20°C~ 60°C Operating: 10 ~ 85% Non Operating: 5~85% Vibration Frequency: 5~200Hz, Acceleration: 1.0g Test Duration: 60 minutes per axis VGA x1; DVI x1; HDMI x1; UpstreamUSB3.0 x1; Downstream USB3.0 x4 Menu Functions: Luminance, Image Setup, Color Temp, OSD Setup 58 W CE & FCC All product specifications are subject to change without notice. Last update: 05-11-2015 AMT-1023C-DH25 All product specifications are subject to change without notice. 23" LED Touch Monitor Last update: 05-11-2015
AMT-1023C-DH25
物料型号:TB6612FNG 器件简介:TB6612FNG是一款双通道H桥电机驱动器IC,具有高速响应、低噪声和低功耗等特点。
引脚分配:1-GND, 2-VM, 3-A1, 4-OUT1, 5-IN1, 6-IN2, 7-OUT2, 8-A2, 9-B2, 10-B1, 11-A1, 12-GND, 13-STBY, 14-PWMA, 15-AIN2, 16-AIN1, 17-BIN2, 18-BIN1, 19-PWMB, 20-VCC。
参数特性:工作电压范围为4.5V至18V,最大输出电流为2A(每通道),具有过流、过热、欠压保护。
功能详解:支持PWM调速,可实现电机正反转和停止控制,具有多种控制模式。
应用信息:适用于小型电机驱动、机器人控制、家用电器等领域。
封装信息:TSSOP-20封装。
AMT-1023C-DH25 价格&库存
很抱歉,暂时无法提供与“AMT-1023C-DH25”相匹配的价格&库存,您可以联系我们找货
