BB-BR700G
BB-BR700G
    B+BSMARTWORX
    PWR SUPPLY UPS 450W 120VAC
BB-BR700G 数据手册
BR700G Product data sheet Characteristics Overview Model Name APC Power-Saving Back-UPS Pro 700 Includes USB cable , User Manual Standard Lead Time Usually in Stock Product Distribution Anguilla , Aruba , Bahamas , Barbados , Belize , Bermuda , Canada , Cayman Islands , Colombia , Costa Rica , Cuba , Dominican Republic , Ecuador , El Salvador , Guatemala , Guyana , Haiti , Honduras , Jamaica , Mexico , Nicaragua , Panama , Puerto Rico , Trinidad And Tobago , Turks And Caicos Islands , United States , Venezuela , VIRGIN ISLANDS (UNITED STATES) Output Output Power Capacity 420 Watts / 700 VA Max Configurable Power (Watts) 420 Watts / 700 VA Nominal Output Voltage 120V Output Frequency (sync to mains) 50/60Hz +/- 3 Hz Output Frequency (sync to mains) Line Interactive Waveform Type Stepped approximation to a sinewave Output Connections (3) NEMA 5-15R (Battery Backup) , (3) NEMA 5-15R (Surge Protection) Input Nominal Input Voltage 120V Input Frequency 50/60 Hz +/- 3 Hz (auto sensing) Cord Length 6 feet (1.83 meters) Input voltage range for main operations 88 - 143 V Maximum Input Current 12 A Input Breaker Capacity 15 A Batteries & Runtime Included Battery Modules 1 Battery Slots Empty 0 Typical recharge time 12 hour(s) Replacement Battery RBC17 RBC Quantity 1 Jan 02, 2018 1 Disclaimer: This documentation is not intended as a substitute for and is not to be used for determining suitability or reliability of these products for specific user applications APC Power-Saving Back-UPS Pro 700 Ultra Compact Modbus Gateways Models MESP211D, MESP211T Communications & Management Interface Port(s) USB Available SmartSlot™ Interface Quantity 0 www.advantech-bb.com Surge Protection and Filtering Surge energy rating 354 joules Filtering PRODUCT FEATURES Full time multi-pole noise filtering :5% of IEEE surge let-through : zero clamping response time: instantaneous • Modbus TCP Ethernet, Modbus ASCII & RTU RS-232/422/485 Data Line Protection Coaxial cable for CATV/SATV/modem/Audio-Video (coax connector) NetworkMasters line - 10/100/1000 • Modbus Flexibility – Serial & ,Ethernet, & Slaves Base-T Ethernet (RJ-45 connector) • • • Physical Maximum Height 7.48 inches (190.0 mm) Maximum Width 3.58 inches (91.0 mm) Maximum Depth 12.2 inches (310.0 mm) Rack Height 0U NetModels WeightMESP211D and MESP211T, Vlinx™ 15.73 (7.15Gateways, kg) series lbs Modbus connect ModbusWeight devices to Ethernet networks and let you monitor Shipping 17.61 lbs (8.0and kg) control Modbus devicesHeight from anywhere on the Ethernet LAN9.92 or WAN. Supporting up to 16 Shipping inches (252.0 mm) mastersWidth and 32 slaves, these gateways feature auto-detecting 10/100 Shipping 5.43an inches (138.0 mm) Ethernet copper RJ-45 port and a serial port that supports RS-232/422/485 17.4 inches (442.0 mm) communications via a DB9 male or a terminal block connection. Shipping Depth Master Carton Units View Messaging Status in Real Time Ultra Compact IP30 Metal Enclosure International Power Supply (included ORDERING INFORMATION MODEL NUMBER PROTOCOL MESP211D RS-232/422/485 MESP211T RS-232/422/485 SERIAL PORT DB9 Male Removable Terminal Block ETHERNET ETHERNET PORT CONNECTOR 1 RJ45 1 RJ45 2.0 Master Carton is Dimensions x environments 18.0 inches The product built for use(Length in industrial with a heavy-duty metal Width x Height) enclosure that is panel (standard) or DIN rail mountable (with optional adapters). Master Carton can Weight 16.53 kg ranging from 10 to 30 The product be supplied with a DC power source Color Black VDC and features a barrel connector. A power supply is included. SCC Codes 1073130426679 9 Ease Use Units perofPallet 48.0 ACCESSORIES SMI6-12-V-P5 - Included Power Supply, 12 VDC 6 Watt, 5MM Plug, International AC Input, International AC Blades DRAD35 - Optional DIN rail adapter clip (pair) 232NM9 - Optional mull modem crossover cable Configuration, upgrades and monitoring of the serial server are simple, easy tasks with Vlinx Manager Software. It installs on your PC giving access to Environmental the serial server via your desktop. Remotely manage the Modbus Gateway Operating Environment 32 - This 104 is°Fhelpful (0 - 40for°C) over a LAN or WAN via the build-in web server. off-site troubleshooting can be done with an ordinary Operating Relativeand Humidity 0 - 95 web % browser. Operating Elevation 0-10000 feet (0-3000 meters) Software Support 5 - 113 °F (-15 - 45 °C) Windows XP (32/64 bit), 2003 Server (32/64 bit), Vista 32/64 bit), 2008 Server Storage Relative Humidity 0 - 95 % (32/64 bit), Windows 7 (32/64 bit), Windows 8 (32/64 bit), Windows 10 (32/64 Storage Elevation 0-50000 feet (0-15000 meters) bit). Storage Temperature Audible noise at 1 meter from surface of unit 45.000 dB Online Thermal Dissipation 48.500 BTU/hr Conformance Approvals ENERGY STAR V1.0 (USA) , FCC Part 15 Class B , NOM , TUV , UL 1778 Standard warranty 3 years repair or replace Equipment protection policy Lifetime : $150000 Sustainable Offer Status RoHS Compliant REACH REACH: Contains No SVHCs orders@advantech-bb.com support@advantech-bb.com 2 All product specifications are subject to change without notice. MESP211D & MESP211T_3617ds Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-BR700G 价格&库存
很抱歉,暂时无法提供与“BB-BR700G”相匹配的价格&库存,您可以联系我们找货
