EKI-5525M-ST-AE
EKI-5525M-ST-AE
    B+BSMARTWORX
    NETWORK SWITCH-MANAGED 5 PORT
EKI-5525M-ST-AE 数据手册
Industrial Lite-Managed Ethernet Switch Sell Sheet Lite-Managed ProView Industrial Switches • Remote Monitoring Feature by ProView Technology® • Built-in Modbus/TCP and SNMP agent. • Operation Temp: -10°~ 60°C/-40°~ 75°C • IEEE802.3az, Power Saving feature • Port-based QoS - Port Deterministic function. • Loop Detection feature. • EMS Protected: Level 3 (Surge/ESD/EFT) • Cost-effective solution • CE/FCC/UL508/C1D2/ATEX Typical Usage: - Factory Automation/Machine Automation - Applications that need basic network connectivity and Remote Monitoring. - Ex: Factory Automation, Video Surveillance System, Food Processing, Transportation.. Copper RJ45 Total Type Lite-Managed Model Name EKI-5525/5525I-AE EKI-5525M/5525MI-AE EKI-5525M/5525MI-ST-AE EKI-5525S/5525SI-AE EKI-5525S/5525SI-ST-AE EKI-5725/5725I-AE EKI-5524MM/5524MMI-AE EKI-5524MM/5524MMI-ST-AE EKI-5524SS/5524SSI-AE EKI-5524SS/5524SSI-ST-AE EKI-5528/5528I-AE EKI-5728/5728I-AE EKI-5629C/5629CI-AE EKI-5729F/5729FI-AE EKI-5526/5526I-AE EKI-5726/5726I-AE EKI-5626C/5626CI-AE EKI-5726F/5726FI-AE Optical Fiber 100Base-TX 1000Base-TX (GbE) Ports 100m 5 5 5 5 5 5 6 6 6 6 8 8 10 10 16 16 18 18 5 4 4 4 4 Industrial Ethernet Switches Sell Sheet v1.0 (July. 2015) 100m 100Base-FX S.M:30km, 50/125 um,62.5/125 um M.M:2km, 9/125 um 1000Base-SX 1000Base-LX 550m 10 km 50/125 um,62.5/125 um 9/125 um SFP Slot 100/1000Mbps 1 (Multi-mode)-SC 1 (Multi-mode)-ST 1 (Single-mode)-SC 1 (Single-mode)-ST 5 4 4 4 4 8 2 (Multi-mode)-SC 2 (Multi-mode)-ST 2 (Single-mode)-SC 2 (Single-mode)-ST 8 8 8 2 Combo 2 16 16 16 16 2 Combo 2 Industrial Managed Ethernet Switch Sell Sheet Managed Industrial Switches • Advanced Network Traffic Control/Management • Fully Layer2 Protocol Features (Security, Redundancy, Managed, Optimize) • Port monitoring and diagnostics • 20ms Self-healing X-Ring • Operation Temp: -10°~ 60°C/-40°~ 75°C • UL Class1 Divsion2 / UL508 – Complaint • Industrial Level ESD/EFT/Surge Protection Typical Usage: - Large Networks (many switches) - Applications where downtime is Expensive & Redundancy is required - Where Ethernet/IP “Implicit” type messaging is used for I/O type communications - Ex: Factory - Process Management/ ITS-Traffic Management and Video Surveillance Optical Fiber Copper RJ45 Total Type Managed Model Name EKI-7554MI/7554SI EKI-7654C-AE EKI-2548I-AE EKI-7758F-AE EKI-2748FI-AE EKI-2748CI-AE EKI-7657C/7657CI-AE EKI-7659C/7659CI-AE EKI-7559MI/7559SI-AE EKI-7659CPI-AE EKI-9312-C0ID42E EKI-9312-P0ID42E EKI-9316-C0ID42E EKI-9316-P0ID42E EKI-7656C/7656CI EKI-9778-C0SA820E 100Base-TX 1000Base-TX (GbE) 100Base-FX S.M:30km, 50/125 um,62.5/125 um M.M:2km, 9/125 um 1000Base-SX 1000Base-LX 550m 10 km 50/125 um,62.5/125 um 9/125 um SFP Slot Ports 100m 100m 6 6 8 8 8 8 10 10 10 10 12 12 16 16 18 28 4 4 8 2 Combo 2 Combo 4 4 6 + 2 (Combo) 3 Combo 2 Combo 4 4 2 Combo 3 Combo 2 Combo 7 8 8 8 (8 x PoE) 16 2 (Single/Muti-mode)-SC 2 (Single/Muti-mode)-SC 2 Combo 8 8 (PoE/PoE+) 12 12 (PoE/PoE+) 2 Combo 24 Notes: I suffix = Wide Temperature model (-40 to +75C) PA suffix = Full PoE operation with only 24VDC input M-M = Multi-mode Fiber (short distance, < 1.2 mi.) S-M = Single-mode Fiber (long distance, > 1.2 mi.) Combo = Either RJ-45 Cooper or Fiber Interface (Using SFP transceiver module) Industrial Ethernet Switches Sell Sheet v1.0 (July. 2015) 100/1000Mbps 2 Combo 4 4 4 4 2 Combo 4 x 10G Industrial SFP Modules Sell Sheet Small Form-factor Pluggable (SFP) Transceiver Modules • Extend network connections • Operation Temp: 0°~ 70°C and -40°~ 85°C (By different P/N) • Industry standard small form pluggable (SFP) package • Class 1 laser product complies with EN 60825-1 • Hot pluggable • LC connector Type 100Base-FX 1000Base-TX 1000Base-X Typical Usage: - Connections over 300 feet - Work with devices (Switches, Media converters, etc.) with SFP slots Model Name Category Speed Distance SFP-FXM/LC 100Base-FX M.M 100Mbps 1.2 mi. (2 km) SFP-FXS/LC-30 100Base-FX S.M 100Mbps 18.6 mi. (30 km) SFP-GTX/RJ45 1000Base-T 1000Mbps (1 Gbps) 328 ft. (100 m) SFP-GSX/LC 1000Base-SX 1000Mbps (1 Gbps) 1804 ft. (550 m) SFP-GLX/LC-10 1000Base-LX 1000Mbps (1 Gbps) 6.2 mi. (10 km) SFP-GLX/LC-20 1000Base-LX 1000Mbps (1 Gbps) 12.4 mi. (20 km) SFP-GLX/LC-40 1000Base-LX 1000Mbps (1 Gbps) 24.9 mi. (40 km) SFP-GXD/LC-50E 1000Base-ZX 1000Mbps (1 Gbps) 31.3 mi. (50 km) SFP-GZX/LC-70E 1000Base-ZX 1000Mbps (1 Gbps) 43.8 mi. (70 km) Industrial PoE/PoE+ Ethernet Switch Sell Sheet PoE / PoE+ Industrial Ethernet Switch: What is Power over Ethernet? • • • • Data and Power over a single Ethernet cable Transmitting safe and uninterrupted power over existing LAN infrastructure IEEE 802.3af (15.4W, 48Vdc), PoE IEEE 802.3at (30W, 48Vdc), PoE+ Copper RJ45 Total Type Unmanaged Managed PoE Splitter PoE Injector Model Name EKI-2525P/2525PA EKI-3725P-AE EKI-2726FHPI-AE EKI-2526PI-AE EKI-2528PAI-AE EKI-7629CP/7629CPI-AE EKI-7659CPI-AE EKI-9312-P0ID42E EKI-9316-P0ID42E EKI-2701PSI-AE EKI-2701HPI-AE Optical Fiber 100Base-TX 1000Base-TX (GbE) Ports 100m 5 5 6 6 8 10 10 12 16 2 5 (4 x PoE) 2 (1 x PoE) 2 2 (1 x PoE+) 6 (4 x PoE) 8 (4 x PoE) 8 (8 x PoE) 8 (8 x PoE) Industrial Ethernet Switches Sell Sheet v1.0 (July. 2015) 100m 100Base-FX S.M:30km, 50/125 um,62.5/125 um M.M:2km, 9/125 um 1000Base-SX 1000Base-LX 550m 10 km 50/125 um,62.5/125 um 9/125 um SFP Slot 100/1000Mbps 5 (4 x PoE) 4 (4 x PoE+) 2 2 Combo 2 Combo 8 (PoE/PoE+) 12 (PoE/PoE+) 2 Combo 2 Combo 4 4 Industrial Ethernet Media Converter Sell Sheet Industrial Media Converter • Extend network connections • Operation Temp: -10°~ 60°C/-40°~ 75°C • No setup required – Plug-and-Play • Link Fault Pass-through (LFP) setting • UL Class1 Divsion2 / UL508 – Complaint • Industrial Level ESD/EFT/Surge Protection Typical Usage: - Connections over 300 feet - Applications in electrically “noisy” environments (EMI/RFI) - Applications that require electrical isolation (campus or inter-building) - Ex: Oil&Gas, Factory Automation, Transportation System Copper RJ45 Total Type Model Name EKI-2541M/2541MI EKI-2541S/2541SI EKI-2741SX/2741SXI EKI-2741LX/2741LXI EKI-2741F/2741FI Media Converter Ports 100m 2 2 2 1 1 MM: inexpensive, short-distance (50μm/125 μm) SM: expensive, long-distance (9 μm /125 μm) ST SC 100m 100Base-FX S.M:30km, 50/125 um,62.5/125 um M.M:2km, 9/125 um 1000Base-SX 1000Base-LX 550m 10 km 50/125 um,62.5/125 um 9/125 um SFP Slot 100/1000Mbps 1 (Multi-mode)-SC 1 (Single-mode)-SC 1 1 1 2 Fiber Optic Types and Typical Connectors: • • Optical Fiber 100Base-TX 1000Base-TX (GbE) LC Industrial Ethernet Switches Sell Sheet v1.0 (July. 2015) 1 1 EKI Industrial Ethernet Switch Feature Overview Hardware • • • • • • • IP30/40/67 Protection Metal Chassis Wide Operating Temp. 802.3af PoE/ 802.3at PoE+ Auto MDI/MDI-X Auto Negotiation Store-and-Forward Switching Protection • • • • Certifications Compliance • • • • • • Safety (UL 60950-1, CAN/CSA-C22.2 No.60950, UL508) EMC (EU: EN55011, EN61000, EN55022, EN55024, IEC61000) Shock, Vibration, & Freefall (IEC60068) Hazardous (C1D2) Railway (EN50155) Substation (IEC61850) Magnetically Isolated Ethernet Ethernet ESD Protection Input Power EFT Protection Input Power Surge Protection Layer 2 • 802.1 D/w STP/RSTP • SSL(HTTPS) • 802.1Q(tag) • MAC Violation • • • • • • 802.3AD (LACP) Port Trunking /LACP Port Monitoring/Mirror IGMP v1/v2 Snooping / Query IGMP MLD Snooping IGMP/MLD querier • • • • • • IP Access Security Port Security DHCP Server with IP/Port Binding 802.1X Port Access Control Mac Address Table / Static MAC Multi-User Authentication High Availability • • • • • • Dual Power Inputs Reverse Power Polarity Protection Protective Thermal Overload Fault Relay for External PLC/Controller Auto Bypass 20ms Self-healing X-Ring - - VLAN / QoS • • • • • • • • • 802.1Q Port-based VLAN GVRP 802.1p QoS ToS / DSCP 4 priority queues Rate Limit Storm Control Traffic Statistics Dual Homing Dual Ring Couple Ring Multi Couple Ring Industrial Switches Notes: The feature chart provides an overview of Advantech EKI Ethernet Switches, and there might be minor discrepancies between individual models. Please refer to the datasheets online for the latest information. Industrial Ethernet Switches Sell Sheet v1.0 (July. 2015) Security Managed Industrial Switches Management • • • • • • • • • • • • • Web Browser Telnet Serial Console TFTP SNMPv1/2c/3 SNTP SMTP Syslog Email/Relay Alert RMON/RMON II DMI for SFP PoE Management IPv6 EKI Industrial Layer2 Managed Features EKI Industrial Ethernet Switches (ALL) Feature Auto-MDI/MDI-X Managed Industrial Ethernet Switches Benefit Eliminates the need for Ethernet cross-over cables, by automatically detecting cable type and configuring the port appropriately, greatly reducing installation errors. Allows devices with different capabilities (speed: 10/100/1000M, full/half duplex) to automatically configure ports for optimum communication. Feature DHCP Broadcast Storm Protection Limits broadcast/multicast traffic to a predetermined maximum rate (frames/sec) to prevent network congestion by awry devices. Link Aggregation or Port Trunking ESD Protection Protects Ethernet ports from Electrostatic Discharge (ESD) of up to 4000 Volts when a switch is handled or Ethernet cables are connected or disconnected. IEC61000-4-2 makes certification. Full-duplex operation allows communication in both directions (send & receive) simultaneously, while halfduplex limits one device to wait until the other is finished transmitting. Ingress Protection Rating classifies the protection st against the intrusion of objects by enclosures. The 1 nd /2 digit is for solid objects/liquids. The higher the rating the greater the protection is. Commonly referred to as PoE, and also known as IEEE 802.3af, Power over Ethernet supplies DC (48V, 15.4W) power to attached devices over the same Cat5 cable used for a network connection. Ensures uninterrupted communication, even in the event one external power supply fails. MAC Filtering Small Form-factor Pluggable (SFP) modules are compact electro-optical transceivers that allow a compatible device to connect to a fiber optic network connection. SNMP Auto-Negotiation Full/Half Duplex IP30 / 40 / 67 Protection Power over Ethernet Redundant Power SFP Module Industrial Ethernet Switches Sell Sheet v1.0 (July. 2015) IGMP Snooping Port Mirroring Quality of Service Rate Limiting RSTP (and STP) Benefit Dynamic Host Configuration Protocol (DHCP) allows automatic network settings. A built-in DHCP server eliminates a separate DHCP server, and for easy maintenance it can assign IP addresses by switch port IGMP Snooping allows the switch to listen to multicast/broadcast traffic, and limits it to required switch ports. It minimizes network traffic, and is recommended for Ethernet/IP “Implicit” I/O systems. Link Aggregation (IEEE 802.3ad), sometimes called Port Trunking, is a provision to connect multiple ports in parallel to increase throughput between switches and offer higher availability through link redundancy. MAC Filtering is a means for enhanced network security, by limiting network access by unique Ethernet device ID (MAC address). Specific devices can be either allowed or denied network access. Port Mirroring allows eavesdropping on data traveling in or out one or more switch ports. Used with a PCbased diagnostics program or protocol analyzer, it is a valuable for troubleshoot communications problems. Quality of Service (IEEE 802.1p) is a means of prioritizing network traffic, to ensure time critical message delivery. For example, messages between a HMI and PAC can be given priority over e-mail. Rate Limiting allows traffic to be throttled to a specified rate (kbps), in an effort to improve network performance. Limits can be placed on both incoming and outgoing traffic, on a port-by-port basis. Rapid Spanning Tree (IEEE 802.1w), replaces Spanning Tree Protocol (IEEE 802.1D), and provides redundant switch-to-switch connections, generally adapting to topology changes in 2 to 6 seconds. The “Modbus” of the IT world, Simple Network Management Protocol allows remote monitoring and control of network devices. IT administrators use it to determine which devices service or maintenance. Store-and-Forward Surge (EFT) Protection A mode of transmission where data is received completely, before re-transmission to the final destination, allowing only error-free data transmission, and devices of different speeds. Protects the switch‟s power supply from external electrical noise and voltage spikes (Electrical Fast Transients) up to 3000V. Industrial Ethernet Switches Sell Sheet v1.0 (July. 2015) VLAN X-Ring Virtual Local Area Networks (802.1Q) allow the creation of multiple logical networks within a single physical network, providing network segmentation for improved performance and enhanced security. X-Ring, Advantech‟s proprietary self-healing ring technology, a high performance alternative to RSTP, ensures recover from loss of power to a switch, or a cable/fiber fault, within 20 ms (for up to 250switches).
EKI-5525M-ST-AE 价格&库存
很抱歉,暂时无法提供与“EKI-5525M-ST-AE”相匹配的价格&库存,您可以联系我们找货
