BB-SL30200110-SWH
BB-SL30200110-SWH
    B+BSMARTWORX
    SMARTSTART 1E,232,I/O,2S,SWH
BB-SL30200110-SWH 数据手册
SmartStart INTELLIGENT 4G LTE ROUTER & GATEWAY + For industrial IoT and consumer focused high speed data applications + Ethernet, serial RS-232 and I/O for connecting a wide array of field assets with DIN rail or wall mounting + Low power consumption for solar and battery power applications + Exceptionally resilient wireless and wired connection + Enhanced memory to host custom software applications and a wide variety of protocols + Easy deployment, mass maintenance and troubleshooting with B+B SmartWorx remote management and monitoring tools + Loaded with advanced features to secure your data The SmartStart™ LTE family of cellular routers and gateways are the perfect way to connect RS-232 and Ethernet devices to a cellular network. Industrial M2M and IoT applications include Ethernet lottery machines, ATM stations, kiosks, gaming terminals along with RS-232 traffic controllers, meters, UPS systems, PLCs and much more. The processor is powerful enough to handle the full range of LTE communications capabilities, including video streams. The internal memory provides ample storage for custom scripts, software applications and a wide variety of protocols. In addition to its Ethernet and RS-232 ports, SmartStart™ has built-in digital I/O connectivity. Competing routers in the same price range generally provide only Ethernet or RS-232. StartSmart™ provides all three. SmartStart™ combines best-in-class power consumption with LTE performance and is optimized for solar and battery powered applications. Low Power Mode extends battery life by dropping power consumption to 40 mW, and can be triggered by timers, low voltage detection or I/O. SmartStart™ is the industry’s only cellular gateway with power consumption equivalent to 2G devices. It is DIN rail and panel mountable. The router supports VPN tunnel creation using various protocols to ensure safe communications. The router provides diagnostic functions which include automatic monitoring of the wireless and wired connections, automatic restart in case of connection losses, and a hardware watchdog that monitors the router status. SmartStart™ is an excellent fit for applications that are migrating to LTE technology. SmartStart™ provides fallback to 3G/2G technologies to ensure that connectivity is reliable in areas where LTE is still under development. This futureproofs your existing installations and protects your investment. You can upgrade your systems according to your own schedule, as SmartStart™ will continue to connect your legacy devices, even after the cellular providers sunset their 2G and 3G cellular networks. SmartStart™ is easy to install using SmartWorx HUB™, a full featured configuration and monitoring tool. Our VPN configuration tool, SmartCluster™, makes it easy to configure multiple routers via the same VPN tunnel. ORDERING INFORMATION – Antennas & Power Supplies Sold Separately MODEL NO. - ORDER CODES NAM* LTE CAT.1 EMEA & LATAM LTE CAT.4 1X ETHERNET RS232 I/O 2X SIM SL30200110      SL30210110      SL30200110-SWH      SL30210110-SWH      SL30400110      SL30410110      SL30400110-SWH      SL30410110-SWH      WI-FI SMARTWORX HUB         * North America www.advantech-bb.com / Enabling an Intelligent Planet All product specifications are subject to change without notice. SmartStart_4116ds.indd SmartStart INTELLIGENT 4G LTE ROUTER & GATEWAY ACCESSORIES - INCLUDED ACCESSORIES - SOLD SEPARATELY ORDER CODE DESCRIPTION ORDER CODE DESCRIPTION BB-KN-MO4-1.5 SmartStart PS cable 4-wire, 1,5m, GA110 Antenna LTE, Magnet Mount SBD25 SmartStart DIN Clip TG30 Antenna LTE, Terminal Quick Start Guide AW-A2458G Antenna Wi-Fi 2.4 & 5.8 GHz RPS-MO4-M PS, SmartStart, 12V/1A BB-KN-MO4-1.5 PS cable 4-wire, 1,5m, SmartStart SBD25 DIN Clip - SmartStart SPECIFICATIONS NETWORKING Network and Routing DHCP Server, NAT/PAT, VRRP, Dynamic DNS client, DNS proxy, VLAN, QoS, DMVPN, NTP Client/ Server, IGMP, BGP, OSPF, RIP, SMTP, SMTPS, SNMP v1/ v2c/ v3, Backup Routers, PPP, PPPoE, SSL, Port Forwarding, Host Port Routing, Ethernet Bridging Security HTTPS, SSH, VPN tunnels, SFTP, DMZ, Firewall (IP Filtering, MAC address filtering, Inbound and outbound Port filtering) VPN Tunnelling Open VPN client and server and P2P, L2TP, PPTP, GRE, EasyVPN, IPSec with IKEv1 and IKEv2 Configuration Web server, SSH, Four configuration switchable profiles, Automatic configuration update from server, Backup configuration, Restore configuration Firmware Management Automatic firmware update from server, Locally via LAN or remotely OTA (HTTP, HTTPS), Over-the-Air software updates, Over-the-Air cellular module update from FW Diagnostic One CLICK report - current configuration / factory identification / system log / kernel log / reboot log / routing table, Remote diagnostics possible via SSH Status Network Status, DHCP Status, IPSec Status, Statistics history for last 60days Log System Log, Reboot Log, Kernel Log Controlling and Diagnostic SMS, SNMP v1/v2c/v3, Statuses Event Engine StartUp script & Up/Down script (Bash, Python), Digital Input, Network Parameters, Data Usage, Timer, Power, Device Temperature. Report Types: RAP, SMS, email, SNMP Trap, TCP (csv, xml, binary) Other Support of IPv6 PORTS, LED, ANTENNAS Ethernet RJ45, 10/100 Mbps, 1.5kV RMS SIM NAM/EMEA 1/2 Mini SIMs (2FF) MECHANICAL Plastic case with metal DIN rail Plastic LED ndicators PWR, DAT, WAN, ETH Enclosure Dimensions 87x30x127mm (150mm including wall month sides) 2x ANT WiFi antenna - *optional RS232 I/O SMA connectors R-SMA connector DB9 Female 1x Digital Input On Voltage: 2.7V to 36VDC (4-Way Molex moni-fit connector) Weight 187 g SUPPORT AND WARRANTY Limited lifetime warranty, Free device software upgrades. CELLULAR MODULE PARAMETERS SL304 Cat. 4 - EMEA & LATAM SL302 Cat. 1 - NAM - AT&T (Verizon Coming Soon) LTE parameters Bit rate 150 Mbps (DL) / 50 Mbps (UL) LTE FDD Cat.4, 3GPP release 9 compliant Supported frequencies: 800 / 900 / 1800 / 2100 / 2600 MHz Bit rate 10 Mbps (DL) / 5 Mbps (UL) LTE FDD Cat.1, 3GPP release 9 compliant Supported bandwidths: 5 Mhz, 10 Mhz, 20 MHz Supported frequencies: 700 / 850 / 1700(AWS) / 1900 MHz WCDMA Bit rate 42.0 Mbps (DL) / 5.76 Mbps (UL) Supported frequencies: 900 / 2100 MHz Bit rate 384 kbit/s (DL) / 384 kbit/s (UL) Supported frequencies: 850 / 1900 MHz GPRS/EDGE parameters Bit rate 236 kbps (DL) / 236 kbps (UL) Supported frequencies: 900 / 1800 MHz - orders@advantech-bb.com support@advantech-bb.com Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 SmartStart INTELLIGENT 4G LTE ROUTER & GATEWAY SPECIFICATIONS - CONTINUED POWER, CONSUMPTION, ENVIRONMENTAL, IP COVER WI-FI 9–36VDC (4-Way Molex monifit connector) Power Supply Power Consumptionwith WiFi - Average/Peak/Sleep Mode 2,7 / 5.5 W / 40 mW Power Consumption without WiFi - Idle/Average/Peak/Sleep Mode 2,1 / 4.8 W / 40 mW Current with WiFi 0.65 A Max Current without WiFi 0.55 A Max Temperature Range with WiFi – Operating / Storage Temperature Range without WiFi – Operating / Storage -25 to +55 °C / -40 to +85 °C -40 to +75 °C / -40 to +85 °C Humidity – Operating / Storage (noncondensing) 0 to 95 % / 0 to 95 % Cold Start -40 °C Operating Altitude 2000 m / 70 kPa Enclosure Rating IP30 Antenna Connector R-SMA – 50 Ohms Supported WiFi Band 2.4 GHz - Number of clients: 55 Standards 802.11b, 802.11g, 802.11n Encryption None, WEP, TKIP, AES Authentication Open, Shared, WPA–PSK, WPA2–PSK, WPA2-Enterprise, 802.1 - RADIUS 2.4 GHz Supported Channels 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 Type of Device Access point, Client WiFi WiFi 802.11 b/g/n, AP or Client operating, Supported WiFi band - 2.4 GHz, Number of clients: 55 WiFi - Authentication/Cipher Channel Width [MHz] WPA2-PSK/AES, WPA-PSK/AES, none/none Throughput of TCP [Mbps] 20 40 40 60 INDUSTRY CERTIFICATIONS & APPROVALS Emissions/ Immunity EN 55022, EN 61000-6-2, ETSI EN 301 489-1 V1.9.2, FCC part 15 class B (all pending) Safety Hazardous Locations: EN 60950 Power: EN 61131-2 Vehicle Usage: E-Mark Environmental: RoHS, REACH, WEEE STANDARDS AND REGULATIONS FOR EMEA ROUTERS - SL304XXXXX STANDARDS AND REGULATIONS FOR NAM ROUTERS - SL302XXXXX Industrial FCC 15.107 Class B, FCC 15.109 Class B, PTCRB, ETSI EN 301 489-1 v1.9.2, IEC 61000-6-2:2005, IEC 61000-6-3:2006 Safety EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013, EN 62311:2008 Carrier Approvals AT&T REACH and RoHS compliant EMC ETSI EN 301 489-1 v1.9.2, IEC 61000-6-2:2005, IEC 61000-6-3:2006 Safety EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013, EN 62311:2008 E8 – EMC for device in transportation E8 homologation number: 10R – 04 8634 REACH and RoHS compliant DIV, ANT antenna connector RS232 DB9 female connector Robust metal DIN holder ETH 10/100 connector Wall mounting Robust plastic case IN/OUT LED Indicators WiFi antenna connector orders@advantech-bb.com support@advantech-bb.com PWR connector RESET button Primary and backup SIM for cellular module Corporate Headquarters: 707 Dayton Road, PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park, Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
BB-SL30200110-SWH 价格&库存
很抱歉,暂时无法提供与“BB-SL30200110-SWH”相匹配的价格&库存,您可以联系我们找货
