EKI-1224-BE
EKI-1224-BE
    B+BSMARTWORX
    ROUTER 4G LTE INTL 2G/3G FB
EKI-1224-BE 数据手册
Industrial Ethernet Serial Device Servers Sell Sheet Ethernet Serial Device Servers Modbus Gateway • Basic Serial to Ethernet connectivity • Operation Temp: -10°~ 60°C/-40°~ 75°C • RS-232/422/485, software selectable • Operation Mode: Virtual COM/TCP&UDP/Pair Connection • Dual LAN port for redundancy (EKI version) • Isolation and EMC Level 4 Protections. • CE/FCC/C1D2 (EKI version) • Basic Serial to Ethernet connectivity • Operation Temp: -10°~ 60°C/-40°~ 75°C • RS-232/422/485, software selectable • Operation Mode: Virtual COM/TCP&UDP/Pair Connection • Dual LAN port for redundancy (EKI version) • Isolation and EMC Level 4 Protections. • CE/FCC/C1D2 (EKI version) • Modbus protocol compliant. Typical Usage: - Stand-alone systems require the serial data through Ethernet. - Ex: Machine automation, PLC connection. Type Standard Serial Device Server Model Name ADAM-4570-CE ADAM-4570L-DE ADAM-4571-CE ADAM-4571L-DE EKI-1521-BE EKI-1521I-BE EKI-1521CI-BE EKI-1522-BE EKI-1522I-BE EKI-1522CI-BE EKI-1524-BE EKI-1524I-BE EKI-1524CI-BE EKI-1528-BE EKI-1528T-VDC-BE EKI-1526-BE EKI-1526T-VDC-BE Typical Usage: - Stand-alone systems require the serial data through Ethernet. - Ex: Machine automation, PLC connection. Copper RJ45 Serial Port - RJ45 or RJ48 Dual IP Setting 100/100Mbps 100m 50bps ~ 921.6Kbps Note: any baud rate setting RS232 RS232/422/485 - 1 - 1 - 1 Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes 1 2 2 2 2 2 2 2 2 2 2 2 2 2 Notes: L suffix = Low-cost version D suffix = Daisy-Chain Connectivity List Price = Advantech’s Selling list price (Reference only, it’s adjusted without notification) Industrial Serial Device Server Sell Sheet v1.0 (April. 2015) Protection Added 1 1 2 2 1 1 1 2 2 2 4 4 4 8 8 16 16 Wide Temp Wide Temp + Isolation Wide Temp Wide Temp + Isolation Wide Temp Wide Temp + Isolation Type Modbus Serial Device Server Model Name ADAM-4572-CE EKI-1221-BE EKI-1221I-BE EKI-1221CI-BE EKI-1221D-AE EKI-1222-BE EKI-1222I-BE EKI-1222CI-BE EKI-1222D-AE EKI-1224-BE EKI-1224I-BE EKI-1224CI-BE Copper RJ45 Serial Port - RJ45 or RJ48 Dual IP Setting 100/100Mbps 100m 50bps ~ 921.6Kbps Note: any baud rate setting RS232 RS232/422/485 Yes Yes Yes Yes Yes Yes Yes Yes Yes 1 2 2 2 2 2 2 2 2 2 2 2 1 1 1 1 1 2 2 2 2 4 4 4 Protection Added Wide Temp Wide Temp + Isolation Wide Temp Wide Temp + Isolation Wide Temp Wide Temp + Isolation Wireless Serial Device Servers • Standard Wireless – IEEE 802.11 b/g or b/g/n (EKI-136x series) • Supports WEP, WPA and WPA2 security mechanism • Operation Temp: -10°~ 60°C • C1D2 / UL508 – Complaint • Industrial Level ESD/EFT/Surge Protection Typical Usage: - Link any serial device to an IEEE 802.11 b/g/n network. - Ex: Remotely Tank control/Factory Automation/ AGV (Automatic Guide Vehicle) Type Wireless Serial Device Server Model Name Total Ports EKI-1351-AE EKI-1352-AE EKI-1361-AE EKI-1362-AE Industrial Serial Device Server Sell Sheet v1.0 (April. 2015) 1 2 1 2 Copper RJ45 Wireless Serial Port - RJ45 or RJ48 10/100/1000Mbps 100m RP-SMA (Female) Standard 50bps ~ 921.6Kbps Note: any baud rate setting RS232 RS232/422/485 1 1 802.11 b/g 802.11 b/g 802.11 b/g/n 802.11 b/g/n 1 2 1 2 Serial to USB Converter • Full compliance with USB V1.1 and V2.0 specifications (USB-Series) • RS-232/422/485 port supported • Plug & Play installation • Hot swap function supported Typical Usage: - Allows PC users to connect a serial device to a system that use a USB interface. USB Port Type Serial to USB Converter Model Name Total Ports USB-4604B-AE USB-4604BM-AE Accessory Sell Sheet Industrial Serial Device Server Sell Sheet v1.0 (April. 2015) 4 4 USB 1.1 Type B Serial Port - RJ45 or RJ48 USB 1.1/2.0 Type B 1 1 RS232 50bps ~ 921.6Kbps RS232/422/485 4 4 Contact Information: Ken Kao Product Sales Manager of Industrial Communication Advantech Corporation, Intelligent Connectivity Group I 11380 Reed Hartman Hwy, Cincinnati, OH 45241 Tel: 513.742.8895 ext.332 I Fax: 513.742.0554 I Mobile: 513-250-8581 www.advantech.com Industrial Serial Device Server Sell Sheet v1.0 (April. 2015)
EKI-1224-BE 价格&库存
很抱歉,暂时无法提供与“EKI-1224-BE”相匹配的价格&库存,您可以联系我们找货
