TPC-1551T-E3AE
TPC-1551T-E3AE
    B+BSMARTWORX
    TOUCH PANEL PC 15" XGA ATOM E382
TPC-1551T-E3AE 数据手册
TPC-1551T 15" XGA TFT LED LCD Thin-Client Terminal with Intel® Atom™ Processor Features ƒƒ Industrial-grade 15" XGA TFT LCD with 50K lifetime and LED backlight ƒƒ Intel® Atom™ E3827 1.75 GHz dual-core processor with 4 GB DDR3L SDRAM ƒƒ Wide operating temperature range -20 ~ 60 °C (-4 ~ 140 °F) ƒƒ True-flat touchscreen with IP66-rated front panel/non-flat touchscreen with IP65-rated front panel ƒƒ Front-facing LED indicators to show operating status ƒƒ Durable touchscreen with 5-wire resistive touch control ƒƒ Supports Advantech’s iDoor technology for integrating optional accessories ƒƒ Compact, fanless embedded system with aluminum alloy front bezel and chassis grounding protection ƒƒ Supports Advantech’s SNMP Subagent software ƒƒ Supports Advantech’s WISE-PaaS/RMM remote management software Introduction The TPC-1551T thin-client terminal is equipped with a 15" XGA TFT LCD, low-power Intel® Atom™ E3827 1.75 GHz dual-core processor, and 4 GB DDR3L SDRAM to deliver highperformance computing in a compact, fanless system. For enhanced durability, TPC-1551T features a true-flat touchscreen with IP66-rated front panel, die cast aluminum alloy front bezel, and 5-wire resistive touch control. In addition to supporting a wide operating temperature range (-20 ~ 60 °C/-4 ~ 140 °F), TPC-1551T includes a full-size mini PCIe slot for extending the system functionalities to satisfy diverse automation application needs. Moreover, Advantech’s iDoor technology can be integrated via the mini PCIe slot in order to provide additional I/O connectors, isolated digital I/O, fieldbus protocols, 3G/GPS/GPRS/Wi-Fi communication, and MRAM. Specifications LCD Display General ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ BIOS AMI UEFI Certification BSMI, CCC, CE, FCC Class A, UL Cooling System Fanless design Dimensions (W x H x D) 383.20 x 307.30 x 61.10 mm (15.09 x 12.10 x 2.41 in) Enclosure Front bezel: Die cast aluminum alloy Back housing: SECC Mounting Desktop, Wall or Panel Mount OS Support Microsoft® WES7 (32/64-bit), Windows 7 (32/64-bit), Windows 10 Enterprise LTSB Power Consumption 40.8 W (typical) Power Input 24 VDC +/- 20% Watchdog Timer 1 ~ 255 sec (system) Weight (Net) 3.9 kg (8.59 lb) System Hardware ƒƒ CPU ƒƒ Memory ƒƒ LAN ƒƒ Expansion Slots ƒƒ Storage ƒƒ I/O Intel® Atom™ E3827 1.75 GHz dual-core processor 1 x SODIMM with 4 GB DDR3L SDRAM (supports up to 8 GB) 10/100/1000BASE-T x 2 Full-size mini PCIe 1 x CFast 1 x 2.5" SATA SSD (optional) 1 x RS-232 1 x RS-232/422/485 1 x USB 3.0 1 x USB 2.0 ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ Display Type Display Size Max. Resolution Max. Colors Luminance cd/m2 Viewing Angle (H/V°) Backlight Life Contrast Ratio XGA TFT LED LCD 15" 1024 x 768 16.7M 400 160/140 50,000 hr 700:1 Touchscreen ƒƒ ƒƒ ƒƒ ƒƒ Lifespan Light Transmission Resolution Type 36 million touches at a single point Above 75% Linearity 5-wire analog resistive Environment ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ Humidity Ingress Protection Operating Temperature Storage Temperature Vibration Protection Rear View 10 ~ 95% RH @ 40°C, non-condensing Front panel: IP66 -20 ~ 60 °C (-4 ~ 140 °F) -30 ~ 70 °C (-22 ~ 158 °F) With CFast: 2 Grms (5~500 Hz) With HDD: 1 Grms (5 ~ 500 Hz) (Operating, random vibration) A B C A. External HDD/SSD/iDoor kit (TPC-1251T-EHKE) (Optional) B. CFast C. RS-232 D E F G D. RS-232/422/485 E. USB 3.0 & 2.0 F. LAN (10/100/1000) G. Power Receptor Online Download www.advantech.com/products All product specifications are subject to change without notice. Last updated: 27-Jun-2018 TPC-1551T Dimensions Unit: mm 383.20 306.10 61.10 7 230.10 307.30 296.70 372.70 TPC-1551T Panel Cutout Dimensions: 374.5 x 298.5 mm (14.74 x 11.75 in) Ordering Information iDoor Modules ƒƒ TPC-1551T-E3AE ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ 15" XGA Panel PC, Intel® Atom™ E3827 1.75 GHz Dual-core Processor, 4GB (True-flat touchscreen) 15" XGA Panel PC, Intel® Atom™ E3827 1.75 GHz Dual-core Processor, 4GB (Non-flat touchscreen IP65 certified traditional TPC front panel) ƒƒ TPC-1551H-E3AE Optional Accessories ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ ƒƒ PWR-247-CE TPC-1251T-EHKE 1702002600 1702002605 1702031801 1700000596-11 TPC-1000H-WMKE TPC-1000H-SMKE 60W DC 24V/2.5A Output Power Supply HDD/SSD and iDoor extension kit Power Cable US Plug 1.8 M Power Cable EU Plug 1.8 M Power Cable UK Plug 1.8 M Power Cable China/Australia Plug 1.8 M TPC VESA Mounting Kit from 10" to 17" TPC TPC Stand kit from 10" to 17" TPC Embedded OS ƒƒ ƒƒ ƒƒ ƒƒ 20703WE7PS0004 20703WE7PS0005 2070015041 2070014677 TPC-xx51T/H WS7P x64 MUI Image V4.18 TPC-xx51T/H WS7P x86 MUI Image V4.18 TPC-xx51T-(6)xxAE Win10 2016LTSB V6.01 image TPC-1251T/H WEC7 x64 MUI Image V4.01 S/W Bundle Offering ƒƒ WA-HT1551T-E15H1AE TPC-1551T-E3AE, HMI Runtime 1500 tags, 32G CFast, WES7P ƒƒ WA-ST1551T-E15H4AE TPC-1551T-E3AE, SCADA Runtime 1500 tags, 1TB HDD, WES7P Industrial Thin-Client Terminals PCM-26D2CA-AE PCM-26D1DB-MAE PCM-27D24DI-AE PCM-24D2R4-AE PCM-24D2R2-AE PCM-24R2GL-AE PCM-24R1TP-AE PCM-24S2WF-BE (TPC-1251T-EHKE is required for iDoor modules) SJA1000 CANBus, CANOpen, DB9 x 2 Hilscher netX100 FieldBus, ProfiBus, DB9 x 1 Digital I/O, 16 DI / 8 DO, Isolation, DB37 x 1 OXPCIe-952 UART, Isolated RS-422/485, DB9 x 2 OXPCIe-952 UART, Isolated RS-232, DB9 x 2 2 Port Giga LAN Intel i350 PCIe mini card Intel 82574L, GbE, IEEE 1588 PTP, RJ45 x 1 802.11 a/b/g/n/ac 2T2R w/BT4.1, Atheros QCA6174A Application Software Advantech WebAccess/SCADA is a 100% browser-based IIoT software platform aimed at supervisory control and data acquisition (SCADA) operations. WebAccess/SCADA provides open interfaces that allow our customers and partners to develop unique IoT applications for different vertical markets. In addition to supporting traditional SCADA functions, the platform features an HTML5-based user interface and intelligent dashboard to facilitate cross-platform, cross-browser data analysis. Moreover, WebAccess/SCADA not only offers built-in widgets, but is also equipped with an innovative Widget Builder that enables customers to build their own widgets. Advantech WebAccess/HMI is human-machine interface (HMI) software based on Microsoft's Windows operating system. This software features excellent communication and monitoring capabilities, supports more than 350 PLC communication protocols, and offers a wide choice of screen design objects to satisfy diverse integrations of factory automation and HMI operation and monitoring requirements.
TPC-1551T-E3AE 价格&库存
很抱歉,暂时无法提供与“TPC-1551T-E3AE”相匹配的价格&库存,您可以联系我们找货
