MR-261-009-435-220S
MR-261-009-435-220S
    AIRBORN
    位 连接器
MR-261-009-435-220S 数据手册
BODY SERIES MS .050" Low Profile Metal PC Board Mount Connector MR .050" Low Profile Plastic PC Board Mount Connector (MS & MR mate with MP, MQ, MR, MS, receptacles) OPTIONS CONTACTS SIZE HARDWARE MS .050" Low Profile Metal PC Board Mount Connector MR .050" Low Profile Plastic PC Board Mount Connector (MS & MR mate with MP, MQ, MR, MS plugs) 2 3 2-Row (Sizes 9 thru 37) 3-Row (Size 51) 2 3 2-Row (Sizes 9 thru 37) 3-Row (Size 51) 5 BODY STYLE: Plug, right angle, narrow footprint, w/ mounting holes 6 BODY STYLE: Receptacle, right angle, narrow footprint, w/ mounting holes 1 2 3 4 BODY MATERIAL: Polyphenylene Sulfide (MR only) Electroless nickel shell w/ PPS insulator Electrodeposited cadmium shell w/ PPS insulator Hard anodized black shell w/ PPS insulator 1 2 3 4 BODY MATERIAL: Polyphenylene Sulfide (MR only) Electroless nickel shell w/ PPS insulator Electrodeposited cadmium shell w/ PPS insulator Hard anodized black shell w/ PPS insulator XXX 009, 015, 021, 025, 031, 037, 051 XXX 009, 015, 021, 025, 031, 037, 051 32 33 34 TYPE CONTACTS/TERMINATIONS: Pin, right angle, PCB leads, .109" Pin, right angle, PCB leads, .140" Pin, right angle, PCB leads, .172" 43 44 45 TYPE CONTACTS/TERMINATIONS: Socket, right angle, PCB leads, .109" Socket, right angle, PCB leads, .140" Socket, right angle, PCB leads, .172" 3 5 7 PLATING OPTIONS: 50 u" Au contacts: Au terminations 50 u" Au contacts; Sn/Pb alloy terminations 50 u" Au contacts; SAC305 terminations 3 5 7 PLATING OPTIONS: 50 u" Au contacts: Au terminations 50 u" Au contacts; Sn/Pb alloy terminations 50 u" Au contacts; SAC305 terminations 00 22 41 99 0R 0S KPXX 905 STYLE OF HARDWARE: None Two fixed jacknuts Two turning jackscrews, allen head, retaining ring* Keying hardware, see options below (Body material 2, 3 and 4 only) POLARIZATION / WIRING: Reversed body polarization Standard body polarization Two fixed jacknuts Threaded inserts 00 22 41 99 0R 0S KPXX 905 See page MA-6 for keying options * = Connector body has no mounting holes. = Option not RoHS compliant STYLE OF HARDWARE: None Two fixed jacknuts Two turning jackscrews, allen head, retaining ring* Keying hardware, see options below (Body material 2, 3 and 4 only) POLARIZATION / WIRING: Reversed body polarization Standard body polarization Two fixed jacknuts Threaded inserts See page MA-6 for keying options * = Connector body has no mounting holes. = Option not RoHS compliant Ask About AirBorn's Accelerated Delivery Service .050" 9 thru 51 Contacts MS-25... MP, MQ, MR, MS receptacles MR-25... MP, MQ, MR, MS receptacles MS-26.. MP, MQ, MR, MS plugs MR-26.. MP, MQ, MR, MS plugs (PLUG SHOWN) Call (972) 931-3200 Fax (972) 931-9305 www.AirBorn.com
MR-261-009-435-220S 价格&库存
很抱歉,暂时无法提供与“MR-261-009-435-220S”相匹配的价格&库存,您可以联系我们找货
