MK-4F2-100-175-720S
MK-4F2-100-175-720S
    AIRBORN
    SMD
    100 位 D 型,微型 D 插头,公引脚 连接器
MK-4F2-100-175-720S 数据手册
~AirBorn Right Angle Board mount (Narrow Footprint) MK - 252-031 - 335 - 220S (PLUG) MK - 262- 031 - 445-220S (RCPT) .050" 9 thru 100 Contacts IMK, MLI MATING MATRIX ONNECTO MATES WITH MK-25 ... MK, ML, MM, MN receptacles ML-25 ... MK, ML, MM, MN receptacles MK-26 .. MK, ML, MM, MN plugs ML-26 .. MK, ML, MM, MN plugs .---===::::pt--$-1-1--1- .025±.001 TYP .050±.001 TYP .100 TYP .050 TYP POSITION #1 .100 TYP #2-56 JACKPOST (2 PLCS) SEE PAGE MA - 5 (PLUG SHOWN) H .030 DIMENSIONS SIZE :oNTACl ROWS -9 ~ 21 25 31 37 51 69 100 REV H CTM029 2 3 4 . I A PLUG RCPT PLUG RCPT MAX .775 .925 1.075 1.175 1.325 1.475 1.425 1.725 2.160 .334 .484 .634 .734 .884 1.034 .984 1.284 1.384 MAX MAX .400 .550 .700 .185 .800 .950 1.100 1.050 228 1.350 1.508 .271 MAX 0 F .565 .020 H PLUG RCPT w -.865 .965 -1.115 -1.265 1.215 .294 1 515 z HAROWARE MOUNTING HOLE .096 DIA .420 ~ 1.075 ....__ UNC 1.175 #2 - 56 THREADED UNC THO INSERT 1.080 .450 .520 ....__ 1.180 .650 1.220 .430 .755 1.450 .125 DIA .590 1.000 1.810 #4-40 #2-56 UNC INSER UNC THO #4- 40 UNC INSER .420 .120 y MAX .775 ....__ ~ .251 X MAX .298 .250 .183 .195 .150 .341 300 .394 1.800 .200 .384 .400 www.airborn.com (512) 863-5585 n2-rl " M" Series Connectors M- 43
MK-4F2-100-175-720S 价格&库存
很抱歉,暂时无法提供与“MK-4F2-100-175-720S”相匹配的价格&库存,您可以联系我们找货
