MM-212-037-113-0000
MM-212-037-113-0000
    AIRBORN
    37 位 D 型,微型 D 插头,公引脚 连接器
MM-212-037-113-0000 数据手册
~AirBorn PLUG: RECEPTACLE: PLUG: RECEPTACLE: PLUG MM-312-051-161-45WP MK-342-051-225-2200 MN-311-051-161-45WP ML-341-051-225-2200 xx-xxx-xxx-xxx-xxxx-xxx RECEPTACLE SERIES MM .050" Rugged Metal 110 Connector MN .050" Rugged Plastic 110 Connector (MM & MN mate with MK, ML, MM, MN receptacles) MK .050" Rugged Metal PC Board Mount Connector .050" Rugged Plastic PC Board Mount Connector (MK & ML mate with MK, ML, MM, MN plugs) I ML BODY 2 3 4 1 2 3 4 5 A K T 2-Row (Sizes 9 thru 37) 3-Row (Size 51 & 69***) 4- Row (Size 100) 2-Row (Sizes 9 thru 37) 3-Row (Size 51 & 69***) 4-Row (Size 100) BODY STYLE: Plug, straight, with ears BODY STYLE: Receptacle , straight, standard footprint BODY MATERIAL: Polyphenylene Sulfide (MN on ly) Polyphe nylene Sulfide with electroless nickel shell Polyphe nylene Sulfide with electrodepos ited cadmium shell [El Polyphe nylene Sulfide with hard anodized black shell Polyphe nylene Sulfide with stain less stee l shell Pure Electro-Deposited Aluminum Zinc Nickel Plating Nickel Polymer Plating 1 2 3 4 5 A K T BODY MAT ERIAL: Polyphenylene Sulfide (ML only) Polyphenylene Sulfide with electroless nickel shell Polyphenylene Sulfide with electrodeposited cadmium shell [El Polyphenylene Sulfide with hard anodized black shell Polyphenylene Sulfide with stainless steel shell Pure Electro-Deposited Aluminum Zinc Nickel Plating Nickel Polymer Plating I SIZE I XXX 009, 015, 021, 025, 031 , 037, 051 , 069***, 100 XXX 009, 015, 021 , 025, 031 , 037, 051 , 069***, 100 CONTACTS TYPE CONTACTS/TERMINATIONS: 11 Pin, straight, solder cup 14 Pin, straight, .500" pigtai ls (.018 dia) 15 Pin, straig ht, 1.000" pigtails (.018 dia) 16 Pin, straight, crimped wire 1 3 5 7 PLATING OPTIONS: 50 µ" A u contacts (crimp wire) 50 µ" A u contacts: 10 ,u" Au terminations (solder cup, pigtail) 50 µ " Au contacts ; Sn/Pb alloy terminations (pigtail) [El 50 µ" Au contacts; SAC305 terminations (pigtail) 22 23 24 TYPE CONTACTS/TERMINATIONS: Socket, straight, PCB leads, .1 09" Socket, straight, PCB leads, .140" Socket, straight, PCB leads, .1 72" 3 5 7 PLATING OPTIONS: 50 µ" Au contacts: 10,u" Au terminations 50 µ" Au contacts; Sn/Pb alloy terminations [El 50 µ" Au contacts; SAC305 terminations HARDWARE 00 22 41 42 43 44 45 99 STYLE OF HARDWARE: None Two fixed jacknut assemblies (62*) Two turning jackscrews, alie n head, retai ning ring (81 *) Two long turn ing jackscrews, alien head, retai ning ring (82*) Two turning jackscrews, slot head, retaining ring (83') Two long turn ing jackscrews , slot head, retai ning ring (84*) Two turning jackscrews, alien head, captivated** (85*) Keying hardware, see options below (Body material 2, 3 and 4 only) POLARIZATION I WIRING: 00 None For wiring codes, see page MA-3 & MA-4 00 22 41 99 I xx 00 STYLE OF HARDWARE: None Two fixed jacknut assemblies (62') Two turning jackscrews, alien head, retaining ring•••• (81*) Keying hardware, see options below (Body material 2, 3 and 4 only) POLAR IZATION I W IRING None OPTIONS KSXX Two turn ing jackscrews. See page MA-6 for keyi ng options (KJ') KPXX Two fixed jacknuts and interfacial sealing gasket. See page MA-6 for keying options (KN") 900 lnterfacial sealing gasket OB7 Threaded inserts and interfacial sealing gasket •=U se numbers or letters in parenthesis when ordering size 100. •• = Captive hardware is factory installed and non-removable. ••• = 69 position connectors are available in metal only. •••• = Connector body has no mounting holes. IEl = Option not RoHS compliant REV H C1M058 www.airborn.com (512) 863-5585 "M" Series Connectors M-74
MM-212-037-113-0000
1. 物料型号:文档列出了多种型号的连接器,包括MM-312-051-161-45WP、MK-342-051-225-2200、MN-311-051-161-45WP、ML-341-051-225-2200等。
2. 器件简介:文档描述了不同系列的连接器,如MM系列是0.050英寸的坚固金属连接器,MN系列是0.050英寸的坚固塑料连接器,MK系列是0.050英寸的坚固金属PCB板安装连接器,ML系列是0.050英寸的坚固塑料PCB板安装连接器。
3. 引脚分配:文档提供了2排(9至37尺寸)、3排(51和69尺寸)和4排(100尺寸)的连接器配置。
4. 参数特性:包括连接器的体材料、接触类型、接触/端子类型、镀层选项等。例如,体材料有聚苯硫醚(PPS)、PPS与无电解镍壳、PPS与电沉积镉壳等。
5. 功能详解:文档提供了连接器的详细功能描述,如接触类型包括直插式插座、焊接杯等,以及不同的引脚配置。
6. 应用信息:文档中没有明确提供应用信息,但根据连接器的描述,它们可能用于需要坚固连接的电子设备。
7. 封装信息:文档提供了连接器的封装尺寸,如009、015、021等,以及不同尺寸的连接器配置。
MM-212-037-113-0000 价格&库存
很抱歉,暂时无法提供与“MM-212-037-113-0000”相匹配的价格&库存,您可以联系我们找货
