MK-2C2-025-225-2900
MK-2C2-025-225-2900
    AIRBORN
    25 位 D 型,微型 D 插座,母型插口 连接器
MK-2C2-025-225-2900 数据手册
~AirBorn PLUG: RECEPTACLE: PLUG: RECEPTACLE: PLUG 2-Row (Sizes 9 thru 37) 3-Row (Size 51 or 69) 4-Row (Size 100) 1 BODY STYLE: Plug , straight, with ears 4 I MM .050" Rugged Metal 1/0 Connector (MM mates with MK, ML, MM , MN plugs) BODY 2 3 4 3 BODY MATERIAL: Polyphenylene Sulfide Polyphenylene Sulfide nickel shell Polyphenylene Sulfide cadmium shell [RI Polyphenylene Sulfide black shell 1 3 5 7 IC BODY STYLE: Receptacle, straight, rear panel mount, with fluorosilicone a-ri ng and interfacial seal 2 3 with electrodeposited 4 with hard anodized I XXX 009, 015, 021 , 025, 03 1, 037, 051 , 069, 100 CONTACTS TYPE CONTACTS/TERMINATIONS: Pin, straight, 26 awg solder cup Pin, straight, 24 awg solder cup Pin, straight, .500" pigtails (.018 dia) Pin, straight, 1.000" pigtails ( .018 dia) Pin, straight, crimped wire 21 2A 24 25 26 PLATING OPTIONS: 50 µ" Au contacts (crimp wire) 50 µ" Au contacts: 10 ,u" Au terminations (solder cup , pigtail) 50 µ" Au contacts; Sn/Pb alloy terminations (pigtail) [RI 50 µ" Au contacts; SAC305 terminations (pigtail) 1 3 5 7 I BODY MATERIAL: Polyphenylene Sulfide with electroless nickel shell Polyphenylene Sulfide with electrodeposited cadmium shell [RI Polyphenylene Sulfide with hard anodized black shell SIZE XXX 009, 015, 021 , 025, 031 , 037, 051 , 069, 100 11 1A 14 15 16 I : 2-Row (Sizes 9 thru 37) 3-Row (Size 51 or 69) 4-Row (Size 100) (MN only) with electroless I I I SERIES MM .050" Rugged Metal 1/0 Connector MN .050" Rugged Plastic 1/0 Connector (MM & MN mate with MK, ML, MM, MN receptacles) 1 2 xx-xxx-xxx-xxx-xxxx-xxx RECEPTACLE I I MM-212-031-161-41WQ MM - 2C2- 031-261-26WA-EMI MN-211-031-161-41WQ MM-2C2-031-261-26WA-EMI TYPE CONTACTS/TERMINATIONS: Socket, straight, 26 awg solder cup Socket, straight, 24 awg solder cup Socket, straight, .500" pigtails (.018 dia) Socket, straight, 1.000" pigtails (.018 dia) Socket, straight, crimped wire I I PLATING OPTIONS: 50 µ" Au contacts (crimp wire) 50 µ" Au contacts: 10 ,u" Au terminations (solder cup , pigtail) 50 µ" Au contacts; Sn/Pb alloy temiinations (pigtail) [RI 50 µ" Au contacts; SAC305 temiinations (pigtail) HARDWARE 00 41 42 43 44 45 00 xx STYLE O F HARDWARE: None Two turning jackscrews, alien head, retaining ring (81 *) Two long tu ming jackscrews, all en head, retaining ring (82*) Two turning jackscrews, slot head, retaining ring (83*) Two long tu ming jackscrews, slot head, retaining ring (84*) Two turning jackscrews, alien head, captivated** (85*) POLARIZATION/ WIRING : None For wiring codes, see page MA-3 & MA-4 00 24 26 28 29 1~ STYLE OF HARDWARE: None Two fixed jack nuts, rear panel mount, .040" panel th ickness (64•) Two fixed jack nuts, rear panel mount, .060" panel thickness (66•) Two fixed jacknuts, rear panel mount, .070" panel thickness (68•) Two fixed jack nuts, rear panel mount, .080" panel th ickness (69•) POLARIZATION/ WIRING None For wiring codes , see page MA-3 & MA-4 OPTIONS I EMI EMI a-ring (in lieu of fluorosilicone o-ring) • =Use number in parenthesis when ordering size 100. ••= Captive hardware is factory installed and non-removable. IBl = Option not RoHS compliant REV G C1M120 www.airborn.com (512) 863-5585 "M" Series Connectors M-114
MK-2C2-025-225-2900 价格&库存
很抱歉,暂时无法提供与“MK-2C2-025-225-2900”相匹配的价格&库存,您可以联系我们找货
