MQ-322-051-261-22WD
MQ-322-051-261-22WD
    AIRBORN
    D-Sub 电缆组件 D 型,微型 D 多股,单股 3.00'(914.40mm) 插座,母型插口 至 单条导线引线 无屏蔽
MQ-322-051-261-22WD 数据手册
~AirBorn PLUG RECEPTACLE PLUG: RECEPTACLE: PLUG: RECEPTACLE: I MQ .050" Low Profile Metal 110 Connector MP .050" Low Profile Plastic 110 Connector (MQ & MP mate with MP, MQ, MR , MS plugs) I BODY 2 3 2-Row (Sizes 9 thru 37) 3-Row (Size 5 1) 1 BODY STYLE: Plug, straight, with ears I~ 12 BODY MATERIAL: Polyphenylene Sulfide (MP only) Polyphenylene Sulfide with electroless nickel shell Polyphenylene Sulfide wi th electrodeposited cadmium shell IEl Polyphenylene Sulfide with hard anodized black shell Pure Electro-Deposited Aluminum Zinc Nickel Plating Nickel Polvmer Platino 1 2 3 4 A K T 1 2 3 4 A K T I 1 3 5 7 BODY MATERIAL: Polyphenylene Sulfide (MP only) Polyphenylene Sulfide with electroless nickel shell Polyphenylene Sulfide with electrodeposited cadmium sheil lEJ Polyphenylene Sulfide with hard anodized black shell Pure Electro-Deposited Aluminum Zinc Nickel Plating Nickel Polymer Platino IXXX 009 , 015, 021 , 025 , 031 , 037 , 051 TYPE CONTACTS/TERMINATIONS : Pin , straight, 26 awg solder cup Pin, straight, 24 awg solder cup Pin, straight, .109" Lead Length (.018 dia) SE E NOTE 1 Pin, straight, .125" Lead Length (.018 dia) SEE NOTE 1 Pin, straight, .140" Lead Length (.018 dia) SE E NOTE 1 Pin, straight, .150" Lead Length (.018 dia) SE E NOTE 1 Pin, straight, .156" Lead Length (.018 dia) SE E NOTE 1 Pin, straight, .172" Lead Length (.018 dia) SE E NOTE 1 Pin, straight, .187" Lead Length (.018 dia) SEE NOTE 1 Pin, straight, .250" Lead Length (.018 dia) SEE NOTE 1 Pin, straight, .375" Lead Length (.018 dia) SEE NOTE 1 Pin, straight, .500" Lead Length (.018 dia) sEE NOTE, Pin, straight, 1.000" Lead Length (.018 dia) sEE NOTE, Pi n, straight, crimped wire PLATING OPTIONS: 50 µ " Au contacts (crimp wire) 50 µ " Au contacts (solder cup, pigtail ) 50 µ· Au contacts; Sn/ Pb alloy terminations IE] 50 µ" Au contacts; SAC305 terminations I 21 2A 2D 2E 2F 22 2G 2H 2J 23 2K 2L 2M 24 25 26 1 3 5 7 42 43 44 45 99 00 xx STYLE OF HARDWARE : None Two fixed jacknut assemblies (62") Two turning jackscrews. alien head , retaining ring (81 ") Two long turning jackscrews, alien head , retaining ri ng (82") Two turning jackscrews , slot head , retaining ring (83") Two long turning j ackscrews. slot head, retaining ring (84") Two turning jackscrews, alien head , captivated"" (85") Keying hardware , see options below. (Body material 2, 3 and 4 only) 00 22 41 42 43 44 45 99 POLARIZATION I W IRING None For wiring codes, see page MA-3 & MA--4 Iooxx I SEE NOTE 1 sEE NOTE, PLATING OPTIONS: 50 µ" Au contacts (crimp wire) 50 µ" Au contacts (solder cup, pigtail) 50 1,1" Au contacts; Sn/Pb alloy terminations IE] 50 1,1" Au contacts; SAC305 terminations I STYLE OF HARDWARE: None Two fixed jacknut assemblies (62") Two turning jackscrews. alien head , retaining ring (81 ") Two long turning jackscrews, alien head, retaining ring (82") Two turning jackscrews. slot head, retaining ring (83") Two long turning jackscrews, slot head , retaining ring (84") Two turning jackscrews, alien head , captivated"" (85" ) Keying hardware, see options below. (Body material 2, 3 and 4 only) POLARIZATION/ W IRING None For wiring codes, see page MA-3 & MA--4 I OPTIONS KSXX Two turning jackscrews. See page MA-6 for keying options KPXX Two fixed jacknuts. See page MA-6 for keying options I TYPE CONTACTS/TERMINATIONS : Socket, straight, 26 awg solder cup Socket, straight, 24 awg solder cup Socket, straight, .109" Lead Length (.018 dia) Socket, straight, .125" Lead Length (.018 dia) Socket, straight, .140" Lead Length (.018 dia) Socket, straight, .150" Lead Length (.018 dia) Socket, straight, .156" Lead Length (.018 dia ) Socket, straight, .172" Lead Length (.018 dia ) Socket, straight, .187" Lead Length (.018 dia) Socket, straight, .250" Lead Length (.018 dia) Socket, straight, .375" Lead Length (.018 dia ) Socket, straight, .500" Lead Length (.018 dia) Socket, straight, 1.000" Lead Length (.018 dia) Socket, straight , .500" Lead Length (.018 dia ) Socket, straight, 1.000" Lead Leng th (.018 dia) Socket, straight. crimped wire HARDWARE 00 22 41 KSXX Two turni ng jackscrews and interfacial sealing gasket. See page MA-6 for keying options KPXX Two fixed jacknuts and interfacial sealing gasket. See page MA-6 for keying options ·• = Captive hardware is factory installed and non-removable. CBJ = Option not RoHS compliant REV K CTM026 BODY STYLE : Receptacle , straight, with ears CONTACTS 11 1A 1D 1E 1F 12 1G 1H 1J 13 1K 14 15 16 I 2-Row (Sizes 9 thru 37) 3-Row (Size 51) SIZE XXX 009 , 015, 021 , 025, 031 , 037, 051 I xx-xxx-xxx-xxx-xxxx-xxx 1 SERIES MQ .050" Low Profile Metal 110 Connector MP .050" Low Profile Plastic 110 Connector (MQ & MP mate with MP, MQ, MR , MS receptacles) MQ- 212-031-161-41WS MQ- 222-031 - 2G3-4500 MP- 211-031-161-41WS MP- 221-031-2G3-4500 NOTE 1 = The leads on these contacts are soft copper suitable for forming . www.airborn.com (512) 863-5585 "M" Series Connectors M- 40
MQ-322-051-261-22WD 价格&库存
很抱歉,暂时无法提供与“MQ-322-051-261-22WD”相匹配的价格&库存,您可以联系我们找货
